OK So I have a Bonneville Build started and my original goal was just a top swap and tranny swap. However I have decided I want to build this thing to be a little bit of a beast. I currently have the K-Frame dropped along with everything attached to it. I have the motor tore down to the block and the suspension stuff detached from the K-Frame. I plan on lowering the car 2-3 inches so I am working on that, However I am wanting to put about 350-400 to the wheels. 350 is really the goal but 400 is def a dream at this point. I am basically looking for suggestions at this point. I would like to do this right and make this a reliable build. The car will be getting supercharged. At this Time I dont know if I want to build a top swapped motor (Higher compression) or just go supercharged bottom end. I plan on building the top and bottom end. So Ill be replacing rod and main bearings along with piston rings etc. So any upgrade suggestions to make this reliable are appriciated. I am also going to be upgrading the Diff with an LSD unit and a HD upgrade kit.
1996 Pontiac Bonneville
Series II 3800 L36
4T60E (YES ITS A 60, Only year for the Series II with a 4T60e with OBDII and the updated body style)
Modular pulley Size?
Rockers?
Cams?
Porting?
Intercooler?
Suggestions??
Ill post progress Pictures as I go
Thanks, Will post some pictures of my current progress in a few
