Thread: Hard to Steer
Results 1 to 8 of 8
  1. #1 Hard to Steer
    Jun 2013
    Metro Detroit
    I have a 2007 GXP, and I have replaced the whole suspension including CV axles and bearings (hoping this would cause my clicking/turning issues). Well, I am still getting clicking, and it is difficult to turn the wheel. I can drive it, but I can absolutely tell the difference when driving my brother-in-law's base grand prix 04+. Around turns it will hesitate, and then pull, then hesitate again.
    Do you think I have a rack and pinion problem, and what are my symptoms pointing to? I just can't seem to get a good answer when googling...
    Thanks.
  2. #2 Re: Hard to Steer
    GT Level Member mainecrab's Avatar
    Feb 2008
    You make sure you have PS fluid in the reservoir? Last time I had an issue where it was hard to steer the piping came undone and the PS had no fluid in it to do anything. Though that should be obvious check that first.
  3. #3 Re: Hard to Steer
    if it's only hard to turn left only your rack is bad.
  4. #4 Re: Hard to Steer
    Jun 2013
    Metro Detroit
    Just went and did some tests. Fluid is a little low, but well above the "Add" line.
    The wheel is equally hard to turn left as it is right. I wouldn't call it hard, it should just be easier.. and more free.
  5. #5 Re: Hard to Steer
    check the boots for fluid leaks on the rack inner tie rods. if wet the rack is on its way out. if you hear the pump whine, change that.
    any chance your abs light is on? when the abs light comes on in my car the magna steer quits working and its very firm to steer at idle or slower speeds.
  6. #6 Re: Hard to Steer
    Dec 2012
    troll land
    What yr mag rack?
  7. #7 Re: Hard to Steer
    Jun 2013
    Metro Detroit
    No leaking that I can see and no abs light... Hmm
  8. #8 Re: Hard to Steer
    Jun 2013
    Metro Detroit
    Bump. I'm also getting shuttering at speeds of 55+. Any ideas guys???
  1. wont steer
    By 94grandprix in forum Brakes/Suspension/Chassis
    Last Post: 08-05-2012, 07:11 PM
  2. vibration at 55mph and hard steer
    By TheBeastGTP in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2010, 07:19 PM
  3. noise when i steer
    By mezzoni in forum General Tech Discussion
    Last Post: 03-24-2010, 10:29 PM
  4. can you say torque steer?
    By 99gpse in forum Off Topic Discussion
    Last Post: 03-30-2009, 05:18 PM
  5. Hard to steer left
    By bronzegp in forum General Tech Discussion
    Last Post: 03-05-2009, 07:37 PM
