Thread: need to flush engine
Results 1 to 5 of 5
BlackGT97 need to flush engine 05-22-2014, 07:57 PM
Fivefingerdeathpunch Re: need to flush engine 05-22-2014, 08:05 PM
BlackGT97 Re: need to flush engine 05-22-2014, 08:12 PM
Buggsy Re: need to flush engine 05-23-2014, 11:19 AM
BlackGT97 Re: need to flush engine 05-28-2014, 09:06 PM
  1. #1 need to flush engine
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    long story short, buddy of mine used a scotch brite wheel on a die grinder and now i need to flush the motor bc he didnt cover the lifter valley real good. he just used it on the heads for the intake mating surface. I vacuumed it out the best i could and then flooded the lifter valley with brake cleaner to hopefully flush as much of the aluminum oxide particals out. I also took the oil pan off and going to spray down as much as i can to flush it out. Is this a good flush or is there something else i should do/ something else i should use besides brake cleaner?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: need to flush engine
    Old motor oil?
  3. #3 Re: need to flush engine
    Jul 2011
    Michigan
    i have tons of that actually! i did run some through there when we were done for the night after using the brake cleaner but i can definitely run alot of used oil through it. How about spraying the crank case from underneath?
  4. #4 Re: need to flush engine
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    Mineral Spirits are reasonably cheap, safe, and come in large quantities. Combine them with an engine cleaning gun and you have some spray force too.
    http://www.harborfreight.com/engine-...gun-68290.html
  5. #5 Re: need to flush engine
    Jul 2011
    Michigan
    Ok I have bought and used the engine sprayer abd ran about a gallon through the lifter valley ( a lot of it I just poured in instead of spraying it with the gun), along with about six cans of brake parts cleaner( three sprayed from below into the crank case to drain out). Hopefully this did the trick!
  1. How to Flush/Change Power Steering Fluid on the 3800/3.8L Engine
    By 02NavyBlue in forum How To Write-Ups/Tech Tips
    Last Post: 07-28-2017, 11:02 AM
  2. Engine Flush Additive. Yay or Nay
    By midrange in forum General Tech Discussion
    Last Post: 02-13-2012, 11:07 AM
  3. ENGINE FLUSH - 1999 Grand Prix
    By GOJOEGO2011 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-06-2011, 12:28 PM
  4. Flush....
    Last Post: 04-21-2011, 04:08 PM
  5. To flush or not to flush!
    By SlowM90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-18-2009, 05:58 PM
