Thread: 03 gtp probems. is 87 octane "OK"
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #41 Re: 03 gtp probems. is 87 octane "OK"
    find one thats sold in america not china.
    then again i got a order in a week from china.
  2. #42 Re: 03 gtp probems. is 87 octane "OK"
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    Quote Originally Posted by Buggsy View Post
    Sorry, no I did it wrong. Too many phones in my head. Hold down the volume up + home + power all at once. As soon as you see the little blue writing, let go of just the power button, but hold the other two still. Once you see the menu, let go of the others. Now just scroll down to "wipe cache partition" and push the power button once to do it. It will quickly wipe the cache and take you back to the menu. Now now push the power button once more to reboot.
    got it. it seems like it did an update when it rebooted to. the keyboard is different and everything. does seem more responsive.
  3. #43 Re: 03 gtp probems. is 87 octane "OK"
    Oct 2012
    Chelsea, MI
    also is this going to be able to tell me if I am to lean and KR stuff etc?
    watching youtube videos people are showing rpm and speed and acceleration and ****. I am no seeing any air/fuel or "knock" etc...
    I dont need RPM and speedo or volts.
    I am searching for one local to the US, but not having any luck
  4. #44 Re: 03 gtp probems. is 87 octane "OK"
    KR yes if it's the torque app. Lean...no that's what a wideband is for.
    04 Comp G.
  5. #45 Re: 03 gtp probems. is 87 octane "OK"
    shows long term fuel trims, o2 voltage, KR, trans temp engine temp, timing advance volts, and so on.
  6. #46 Re: 03 gtp probems. is 87 octane "OK"
    I stand corrected
    04 Comp G.
  7. #47 Re: 03 gtp probems. is 87 octane "OK"
    Oct 2012
    Chelsea, MI
    ok, so well worth the 15 bucks. still searching for one local
  8. #48 Re: 03 gtp probems. is 87 octane "OK"
    Oct 2012
    Chelsea, MI
    ok... Here is what I have done in the last week.
    exaust leak fixed. new exaust manifold to downpipe gasket. BTW, they have really updated this. They are a much better design.
    last night I replaced the water pump and both coolant elbows with the dorman 47065HP ones (not plastic). I also cleaned up and fixed some other potential leaks there were up by the heater hoses.
    Bad news is I did not fix all the leaks. The good news is I now know where the last leak is and it will be easy to fix. (heater core hose from the water pump area). new hose and new clamp and it will be all set. NO OTHER LEAKS! and in total I am into it 48 bucks!
    NOW unfortunately my kenwood dvd player wants a code drove to work listening to the after market exaust (which isnt terrible).
    I am getting ever so much closer to headers and a tune! I get a VA paycheck this week I will be watching the classifieds for a good used set.
    I am going to replace all the idler and tensioner pulleys in the next week or two (I am all about preventative maint). I will also be doing a trans fluid/filter change and adding some lucas.
  9. #49 Re: 03 gtp probems. is 87 octane "OK"
    Oct 2012
    Chelsea, MI
    well still no exaust leak. Coolant leaks are all fixed. system I think is finally properly burped. found the code for the kenwood in dash dvd player.
    Next step is to fix the ghetto ass job done on the piller pod (3 piller pod, but no the full replacement) and it looks like crap. on gauge that works is the volt gauge. the boost gauge vacuums but doesnt boost (dont worry I am not going WOT. just gently boosting). The oil pressure gauge is just dead, and none of them light up. So gonna get a replacement pillar pod. and get them working right and wired into the lights.
    I am watching out for headers and then will get a tune, and will be ready to spin this 3.4 pulley at WOT and maybe get some track times!
  1. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  4. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  5. What octane is best for 3.4" set up ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-01-2010, 07:14 AM
