Thread: P0758 + no 1st gear :(
Results 1 to 15 of 15
  1. #1 P0758 + no 1st gear :(
    GT Level Member des19's Avatar
    May 2011
    Ontario
    have a few questions strated up the gtp going home today and looks like it was launching in 2nd. It looks like it has no 1st gear. My question is it fine to drive like this for a bit? Also how F***d am I? whats this gonna cost me!
    bad thing is its am 04 gtp only 120km on it (75k miles approx).
    thanks
  2. #2 Re: P0758 + no 1st gear :(
    Feb 2013
    37.295091, -121.930053
    one of these
    and one of these
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: P0758 + no 1st gear :(
    May 2011
    Ontario
    Is it still fine to drive like this?
  4. #4 Re: P0758 + no 1st gear :(
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    one of these
    and one of these
    *like*
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: P0758 + no 1st gear :(
    As long as you aren't worried about possibly wearing the 2nd clutches a little extra and based on seeing the 2nd pack in many of these transmissions, I wouldn't be worried.
    Is it good, obviously the trans has an issue.
  6. #6 Re: P0758 + no 1st gear :(
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Don't goose it too hard off the line. Easy on the gas into/through second gear should keep it plenty drivable. Getting it fixed could include a multitude of things.
  7. #7 Re: P0758 + no 1st gear :(
    May 2011
    Ontario
    Another issue came up...is there any way that its not the transmission because i don't really feel it slipping at all. What happened today is the car won't even start now. Its in park and it clicks a lot and wont start. Then it won't click at all the next try. Battery is fine and fully charged. I'm guessing the not being able to shift into first gear could be electronically related?!
    wtf is up with this car lol. Almost ready to sell it haha
  8. #8 Re: P0758 + no 1st gear :(
    May 2011
    Ontario
    I also tried starting it in nuetral and same thing
  9. #9 Re: P0758 + no 1st gear :(
    Apr 2012
    Dayton, OH
    Check your grounds
    2012 F150 STX
  10. #10 Re: P0758 + no 1st gear :(
    May 2011
    Ontario
    Check your grounds
    the grounds at the battery?
  11. #11 Re: P0758 + no 1st gear :(
    At the battery, on the body, on the transmission.
  12. #12 Re: P0758 + no 1st gear :(
    May 2011
    Ontario
    the grounds are fine
  13. #13 Re: P0758 + no 1st gear :(
    Well clearly you have a problem, time to start digging.
    Why not actually unbolt all grounds and clean them and put them back together instead of just saying they are fine. Have someone try and turn the car over while you look at the starter and see if any wires are shorting, hit it with a hammer. Or use a DMM on the battery and turn it over, if volts just drop off like crazy, you have a battery issue.
  14. #14 Re: P0758 + no 1st gear :(
    May 2011
    Ontario
    I am going to look into it a little further tomorrow. Can't believe these 2 problems happen at once, they gotta be related in some way. Should the car be able to still start in 2nd or 3rd gear? Maybe it just won't start because of that i dont know
  15. #15 Re: P0758 + no 1st gear :(
    May 2011
    Ontario
    ended up being just the pcm thank god. I had an extra laying around don't know how that happened.
  1. No first and occasional p0758
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-12-2013, 10:59 PM
  2. gear set, 4th gear hub, channel plate gouged! help!
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2013, 04:54 AM
  3. P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors
    By STOCKTA in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2013, 08:36 AM
  4. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
