Thread: Running e85 on stock fuel system
Results 1 to 20 of 37
  1. #1 Re: Running e85 on stock fuel system
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    How would mixing or running e20 and or e30 affect the stock injectors?
    Sent from my PantechP8010 using Tapatalk
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Running e85 on stock fuel system
    Feb 2009
    flintnasty MI
    Quote Originally Posted by K Kraziee View Post
    as mentioned before, you can go up to e50 on stock injectors, but you will be limited to stockish boost. I suspect you could get away with a 3.4 if you had a few mods and you could run clean at 13:1afr.
    what about like a 7 to 1 ratio of 93 and e85 to raise the octane rating mixing at the pump?
    Would be fine. You can mix it with 87 if you are on a stock pulley.
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. fuel rail question...stock for stock..
    By StandAloneCustoms in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2013, 08:11 AM
  3. Am i running out of fuel?
    By GTP4 in forum PCM Tuning
    Last Post: 12-31-2008, 05:11 PM
