Idk if this is the best way to do it, but this is how I would do it.
Brace engine from top, like in the picture scotty showed you.
Unbolt the engine and trans mounts from the subframe
Unbolt steering rack from subframe or you can unhook the power steering lines from the pump and dump ps fluid everywhere and have to futz with hooking up the steering linkage.
Unbolt lower control arms from subframe
Remove 4 subframe bolts
I don't remember all the bolt sizes but I know the subframe bolts are 18mm
