Thread: Anyone recommend ZZP 1.9 modded rocker arms?
Results 1 to 20 of 39
  1. #1 Anyone recommend ZZP 1.9 modded rocker arms?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Wondering if this is a good mod to consider next (while I work on eliminating knock). I am guessing you'd recommend changing the springs as well if I go forward with it?
    If you have done this mod, how well did the car respond with it?
    Thanks in advance
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Mine got rid of 8° of kr I was getting and I ran mine on stock springs
  3. #3 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Had them got rid of like 4-5* of the knock I had at one poinr
    04 Comp G.
  4. #4 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Dec 2012
    troll land
    Planning on getting a set myself
  5. #5 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Omaha, NE
    I'd reccomend a cam over rockers any day.
  6. #6 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Yeah for the cost a cam is much better, only thing rockers have over a cam is easier install.
  7. #7 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Dec 2012
    troll land
    ^this and idle characteristics
  8. #8 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Omaha, NE
    Cam install isn't too bad once you figure out how to get the harmonic balancer off. That's my least favorite part of anything I've ever done on a GP.
  9. #9 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    That's hilarious.. it's a 15min thing to swap a crank sensor.
  10. #10 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Oh yeah I've got that **** down to a science can have it off there in no time at all.
  11. #11 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Quote Originally Posted by 97AutoXVette View Post
    Thanks in advance
    also If you need help swapping springs I have the tools to do it
  12. #12 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Mar 2014
    Cincinnati, OH
    Nice! When I pick up a pair, I may contact you about that. What RPM did you set your shifts at with rockers and the stock springs by chance?
    Thanks for all of the responses. I am not planning on tearing into the block for a cam swap anytime soon, so will likely go the rockers route for now.
    Any recommendations on what I may need to change in the tune when I put these in? Recommended safe shift RPM?
    2002 GTP sedan:
  13. #13 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    6k rpm
  14. #14 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Mar 2014
    Cincinnati, OH
    6k rpm
    I've seen the magic number 6 before. Stock is set right at 5,350 at least in my 1999 GTP. Have you guys seen some good/safe gains by bumping the shift points up by that much? by gains, I mostly mean acceleration/track times by being WOT in more "area under the curve" locations in the power band.
    2002 GTP sedan:
  15. #15 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    It seemed a lot faster on the butt dyno
  16. #16 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Mar 2014
    Cincinnati, OH
    Perfect!
    2002 GTP sedan:
  17. #17 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    May 2012
    Where winter never ends
    Go cam! Best thing I ever did!
    2000 Regal - Winter Beater
  18. #18 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Adecker View Post
    What cam would you recommend given my list of mods???
    If I do cam, I am going to do springs, pushrods, timing chain, the whole 9 yards probably just to be safe...
    2002 GTP sedan:
  19. #19 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    I would go S1x or XP
    Sent from A Galaxy Far Far Away........
  20. #20 Re: Anyone recommend ZZP 1.9 modded rocker arms?
    Oct 2011
    Puyallup WA
    I ran zzp 1.9 rockers with stock springs shifting at 6k no issues easy to install helped with a few degrees of kr and seemed to have better power up top...currently in the middle of a xp can install...rockers deff easy install for a beginner
    08 G8 GT - exhaust Tune
  1. Rocker arms
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2013, 10:52 AM
  2. 1.9 modded rocker arms
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2012, 06:23 PM
  3. rocker arms cam help
    By wking2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-13-2010, 04:39 PM
  4. 1.9 Rocker arms
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:07 PM
