Thread: Will the engine cradle out of a 97-03 work in a 04+
Results 1 to 12 of 12
  1. #1 Will the engine cradle out of a 97-03 work in a 04+
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Well got all new motor mounts in both sides top and bottom of my 05 gtp and noticed the motor is sitting over about a inch or two, to far. Took a closer look at the cradle and it's bent and warped. The passenger side cv axle is pretty much sitting on top of the cradle. I already have had the car on a frame rack and all the fenders and hood line up fine. So it has to be the cradle. Will a 97-03 work? It's hard to find any 04+ parts cars around here. Thinking of going ahead and getting headers and maybe a cam since I'm gonna have to pull the motor anyway.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Will the engine cradle out of a 97-03 work in a 04+
    Yup
    04 Comp G.
  3. #3 Re: Will the engine cradle out of a 97-03 work in a 04+
    stanford Ky
    Ok so the cradles are exactly the same?
    99 gtp- sold
  4. #4 Re: Will the engine cradle out of a 97-03 work in a 04+
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    Well it's the same engine, and it's still a W-body. All of the mounts should be in the same location since they're both 3800s. It should all mount up right.
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  5. #5 Re: Will the engine cradle out of a 97-03 work in a 04+
    The 04 plus engine side mount is about an inch taller than the 97-03
  6. #6 Re: Will the engine cradle out of a 97-03 work in a 04+
    stanford Ky
    I thought they was the same. When I ordered them it said it was for all the years.
    99 gtp- sold
  7. #7 Re: Will the engine cradle out of a 97-03 work in a 04+
    Monte carlo's and impala's came with AL subframes aswell, look for them.
  8. #8 Re: Will the engine cradle out of a 97-03 work in a 04+
    You don't have to pull the engine to swap the subframe just fyi.
  9. #9 Re: Will the engine cradle out of a 97-03 work in a 04+
    Oct 2013
    Iowa
    Just make sure the engine is secure, unbolt everything, swap...done. Just don't forget to re-bolt up the mounts lol.
  10. #10 Re: Will the engine cradle out of a 97-03 work in a 04+
    Yeah... what Slick said. I didn't pull anything when I did mine.
  11. #11 Re: Will the engine cradle out of a 97-03 work in a 04+
    I would use something like a 4x4 that will sit on the inside of the fenders wrap a chain around it and bolt it to the engine using the 2 hoist points.
  12. #12 Re: Will the engine cradle out of a 97-03 work in a 04+
    ill post this right from one of bill threads. he hung my engine the same way when he did my tranny.
  1. Anyone replaced a flexplate without dropping cradle or pulling engine?
    By Damnir in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2013, 11:32 AM
  2. W-body engine/tranny/cradle swap
    By gtpstyl in forum General Tech Discussion
    Last Post: 09-25-2012, 06:45 AM
  3. Subframe or engine cradle bolts HELP
    By ryan12473 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2011, 06:17 AM
  4. cracked engine cradle
    By bobbert88 in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2010, 08:26 PM
