Thread: Fuel gauge problem
Results 1 to 12 of 12
  1. #1 Fuel gauge problem
    Apr 2012
    Leadville
    Hey what up guys. New to the forums.
    Have a question i have a 2002 grand prix 3.1l. And the problem im having is that when ever i start the car the fuel gauge reads full even tho it aint. And like 20 min later that its warmed up it goes all the way to the E even tho i know i do have fuel and goes back and forth within a 20 min time span. Any ideas what this could be and how to fix it? Any help i would appreciate thanks.
  2. #2 Re: Fuel gauge problem
    Jan 2012
    Philadelphia
    not really sure but my GTP's fuel gauge has never worked since i had it there i guess a common part to break in these cars
  3. #3 Re: Fuel gauge problem
    probably a bad sender in the gas pump housing. new fuel pump time.
  4. #4 Re: Fuel gauge problem
    Apr 2012
    Leadville
    how can i get to the fuel pump?
  5. #5 Re: Fuel gauge problem
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    theres a door on the bottom of the trunk under the carpet
  6. #6 Re: Fuel gauge problem
    You don't have to change the whole pump you can change just the fuel level sender.
  7. #7 Re: Fuel gauge problem
    Apr 2012
    Leadville
    Alright thanks guys ill be replacing the sender and keep you guys updated.
  8. #8 Re: Fuel gauge problem
    What dsmuts said.
    Pull the pump, replace the fingers on the sender and boom, done.
    Google, "bonneville fuel level sensor replacement", its a 3 part video.
    Buy this New Fuel Level Sensor (Sending Unit) | eBay
    And do what the man in the video does.
    I've already done this to my car.
  9. #9 Re: Fuel gauge problem
    Oct 2011
    Michigan
    we all have its a grand prix thing
  10. #10 Re: Fuel gauge problem
    GTX Level Member blackflag's Avatar
    Virginia
    Quote Originally Posted by asite57 View Post
    you don't know what your talking about.
  11. #11 Re: Fuel gauge problem
    Oct 2011
    Michigan
    everyone of my friends that has a GP has had there fuel gauge go out because of the sending unit including mine
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  12. #12 Re: Fuel gauge problem
    Albuquerque, NM
    I also have a 2002 GP SE 3.1 that had the same problem. I don't really like to mess with trying to repair on my own. Before trying to replace the sending unit or having a shop replace the fuel pump for about $400 (they won't do the sending unit alone) I poured in a bottle of Prestone gas treatment when tank was an estimated half full, went to the gas station, filled with 88 octane (usually use 86) and added a bottle of fuel injector cleaner. Drove for the next few days until I had gone about 340 miles in city. Should be nearing empty but gauge was still above half. Added another bottle of gas treatment and then filled the tank. Over the next few days the gauge worked normally. Drove another 350 miles and gauge still accurate. Been working fine for the last 3 weeks. You might try this before doing replacement of sending unit.
  1. Another Fuel Gauge Problem
    By SilverGT in forum General Tech Discussion
    Last Post: 06-13-2012, 09:45 PM
  2. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  3. 2000 GT Fuel Gauge problem
    By Hozer1980 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2010, 05:09 AM
  4. 97 gtp fuel gauge problem???
    By iwinagn in forum General Tech Discussion
    Last Post: 07-28-2008, 01:32 PM
