if your springs and struts are still good, how to test: push down on the fender then let the car spring back up, if it stops moving with in 3 bounces the struts are still good. most stop in 1.5 bounces.
if they come back ok, then buy new strut mounts, remove your struts and drop them off at a front end shop, have them change the mounts for you. i was charge liked 25 bucks for the pair. buy your own new mounts form a parts store, or the shop will add the parts mark up on you.
or if you have air tools and a spring compressor you can try changing them yourself. shop doing it is much safer.
