Thread: Squeaky brake pedal?
Results 1 to 3 of 3
  1. #1 Squeaky brake pedal?
    Apr 2014
    Minneapolis
    Hey guys. When I push down on the brakes and let go, the pedal speaks a little bit. Should I just use WD-40 on the pedal and it would stop? Thanks in advance.
    Brent's Boat with Boost - 00' GTP | 3" Downpipe w/cat | U-bend Delete | Polyurethane Motor Mounts | K&N Cold Air Intake |180* Thermostat | Tuned PCM | Powerlog Front Exhaust Manifold | 3.5" Supercharger Pulley | Autolite 104 Spark Plugs | TransGo Shift Kit
  2. #2 Re: Squeaky brake pedal?
    follow the pedal up under the dash, lube the part it moves on. wd-40 wont last long, you can put some grease on it. or white lithium spray grease.
  3. #3 Re: Squeaky brake pedal?
    Apr 2014
    Minneapolis
    Alright. I'll try that later today and get back to ya.
  1. Brake pedal issues..
    By Bluemagic in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2012, 08:18 PM
  2. brake pedal goes to the floor
    By donalda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2011, 01:42 PM
  3. brake pedal very soft
    By Jenco in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2010, 07:38 AM
  4. Very stiff brake pedal?
    By Mesaman4 in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2010, 05:37 PM
  5. low brake pedal
    By johnk in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2009, 07:58 PM
