Thread: Rubbing noise during hard left turn
Results 1 to 8 of 8
  1. #1 Rubbing noise during hard left turn
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I've got a rubbing noise when making a sharp left turn. Sounds like the tire is rubbing against something? Any ideas?
    Sent from my PantechP8010 using Tapatalk
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Rubbing noise during hard left turn
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    are you lowered at all?
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  3. #3 Re: Rubbing noise during hard left turn
    Apr 2013
    Milwaukee
    Nope, stock suspension. It's been doing it since I bought the car a year ago but I'm finally getting tired of it and want to figure out what it is.
  4. #4 Re: Rubbing noise during hard left turn
    Apr 2013
    Milwaukee
    Also seems like it's coming from the passenger side.
  5. #5 Re: Rubbing noise during hard left turn
    Oct 2013
    MARYLAND
    You said passenger side? Check to see if the plastic piece that covers where the belts are is sticking out some. If it's sticking out your tire would be rubbing when you make sharp turns. It could also be the fender liner hanging down some.
    -Thomas Fuller-
  6. #6 Re: Rubbing noise during hard left turn
    Apr 2013
    Milwaukee
    Ok, ya its just left turns, it's totally fine on hard rights. I'll look into that though. Thanks
  7. #7 Re: Rubbing noise during hard left turn
    Most likely it's that plastic.
  8. #8 Re: Rubbing noise during hard left turn
    SE Level Member Gpmadness08's Avatar
    Sep 2013
    Peoria IL
    Had a steering bushing internally that was causing a similar prob in my 08...
  1. Weird Rubbing noise when making a hard left turn
    By K Kraziee in forum General Tech Discussion
    Last Post: 11-27-2013, 03:14 PM
  2. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  3. Rubbing noise
    By cruzn in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2011, 09:56 PM
  4. Odd noise / rubbing
    By Elitemonkie in forum General Tech Discussion
    Last Post: 11-06-2010, 08:06 AM
  5. Rubbing noise from front left tire
    By zeppelinrocks18 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2009, 05:45 PM
