Thread: A little wheel wiggle
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: A little wheel wiggle
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    Thanks. I figured 34 or 36 for a GM. The after market ones that I saw were 34, but GM had some odd stock numbers. I just did one for my sister last year and found her torque value to be something like 250 ft/lbs. :/ The highest my torque wrench goes is 150, so then I'm just guessing after that.
    Also, thanks again for the tip on the spare tire. I'd have popped out the center cap of the rim, and possibly broke it in the process.
  2. #22 Re: A little wheel wiggle
    Arizona
    Quote Originally Posted by Buggsy View Post
    You can also just put a screwdriver in the brake rotor vents that will prevent the assembly from spinning
  3. #23 Re: A little wheel wiggle
    Eau Claire, WI
    Quote Originally Posted by 91parkave View Post
    That's true. It's not nearly as much torque as I expected.
  4. #24 Re: A little wheel wiggle
    i used a 4 foot pipe on a 1/2 drive breaker bar to break mine loose. it was that tight and the exposed threads were rusty too.
  5. #25 Re: A little wheel wiggle
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I used an impact and it came right off
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  6. #26 Re: A little wheel wiggle
    SWPA
    Quote Originally Posted by lewis1952 View Post
    If you want to spend money for a name go ahead I was just giving the another option. All parts made and distributed in the US have to meet SASE standards. Detroit Axle has been around 70 yrs. My god do what ya want. Some people would b#$ch if they were hung with a new rope.
    They are cheap and have crap reviews for a reason. I would rather do the work once. My time is worth more than "saving" $60 but having to do the job 4 times.
  7. #27 Re: A little wheel wiggle
    Mercer, Pa
    Detroit axle doesn't make the bearing, they are the distributor.
    The new rope would break if it was made in China at the same factory that can make and sell 2 bearings with abs sensors and 2 tie rod ends for $76 half way around the world and make a profit.
  1. Passenger wheel and wheel area hot and smeels of hot metal
    By TheInterloper in forum General Tech Discussion
    Last Post: 02-11-2014, 11:59 AM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. Got some wheel questions for you wheel guys
    By gtpeddie in forum Tires & Wheels
    Last Post: 09-22-2013, 07:07 PM
  4. Front wheel squeeks when wheel is straight.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 06-13-2011, 07:02 PM
  5. Steering wheel wiggle
    By Dallasneon in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2010, 11:38 AM
