Thread: need help installing zzp 3" catted downpipe on 04 Impala SS
Results 1 to 19 of 19
  1. #1 need help installing zzp 3" catted downpipe on 04 Impala SS
    GXP Level Member ryangtp89's Avatar
    Maine
    Hey I'm in the process of installing 3" catted downpipe on my 04 impala ss, right now I'm just soaking the bolts down for a few days with pb blaster. anyways the two bolts in the back look difficult to remove and to remove the stock downpipe looks hard. Is there any write up's or a printable instructions for this ? Thanks a lot! By the way I also bought a wizaired cai, tuned pcm, autolite 103 plugs and a 3.5 pulley, I had to drive it home with only the tune pcm, 3.5 pulley and cai, the mechanic was confused with the downpipe and didn't have time for the plog and spark plugs, was it a bad idea driving it home (20miles) ? I didn't make any boost I babied it home.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Aug 2013
    McDonald PA
    if they break off you can replace them easily. and let the car run for a little so everything gets hot and expands respray with blaster. let sit for 5 min and get to work. its easy
  3. #3 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Just use a MAP torch instead of getting the whole pipe hot.
    Upper 2 bolts are easy with some extentions.
  4. #4 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Pennsylvania, USA
    A swivel socket adapter may help you get those two top bolts as well, Harbor Freight has the impact ball joint style for very cheap.
    Also try hitting on the flange a little bit with a hammer to help shock it loose. It helps the PB Blaster penetrate deeper.
  5. #5 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    Sounds good, I have been hitting all of the bolts for the past 4 days with pb blaster, I let the car sit in my driveway soo that way it wouldn't burn off, gave me a good excuse to take the wrangler to work.
  6. #6 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    gardner,mass
    Quote Originally Posted by ryangtp89 View Post
    Yea honestly you wont be reusing the bolt so just try to take them out and if they break or if you cant get them out cut them, then just head to the hardware store or parts store and pick up some grade 8 course thread bolts to replace them.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  7. #7 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    I'm not sure if the plog or downpipe came with any new bolts.
  8. #8 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    The guy at the shop didn't do it again he was afraid he was going to break the bolts on the head and the downpipe. Well time to find another shop.
  9. #9 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    would it be safe to drive around for alittle without the downpipe and plog ? the tuned pcm, 3.5 pulley, Al 104 plugs and wizaired cai is already on.
  10. #10 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    103s are a little cold for a stock compression car running 10 psi. 104 would be more appropriate. Less misfires at idle and better fuel economy.
    As far as the pulley without exhaust mods, just don't get into boost and all will be okay.
    Better idea would be to scan and see if you have knock as is. You might not, but likely will.
  11. #11 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    I'm sorry I do have the autolite 104's I had to check my sale order on my email to make sure. But defently stay away from the boost is what I have been doing.
  12. #12 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    gardner,mass
    n/m
  13. #13 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    what does n/m stand for ? Is there any write ups for removing the front exhaust manifold ? It looks tight, just wondering if theres any tricks to remove it.
  14. #14 need help installing zzp 3" catted downpipe on 04 Impala SS
    Aug 2013
    McDonald PA
    Pb blaster for a couple days. Let the motor run to heat it up and steady pressure don't wrench on it.
    Edit: there is a recent thread on it
  15. #15 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Aug 2013
    McDonald PA
    Installing New PLOG Exhaust Manifold - Help http://www.grandprixforums.net/showthread.php?t=88922
  16. #16 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    Thanks a lot guys! I went through 2 cans of pb blaster and let it sit for a week before I brought it to the shop but they were still too much of a nancy to try and remove the exhaust manifold. Well I went ahead and bought some Kroil! If you guys never heard of it look it up!
  17. #17 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    just installed it and its still loud, i left out the o2 sensor because the old one was stripped finally installed new one and its sounds the same. the downpipe never came with a gasket. should i get one ?
  18. #18 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Aug 2013
    McDonald PA
    The one to the rez you should get
  19. #19 Re: need help installing zzp 3" catted downpipe on 04 Impala SS
    Maine
    its pretty quiet now just alittlw louder than when it was before the install, does that sound normal ?
  1. 3" catted zzp downpipe
    By Clar2478 in forum General Tech Discussion
    Last Post: 07-07-2009, 08:14 PM
