With the fan on 1 or 2, everything seems to work fine. A/C blows cold(ish) and heater blows hot. But if I turn the fan to 3, (no matter the temp setting or if the a/c is on or off) I start getting a slight electrical burning smell. Turn it to 4 and the smell gets worse as well as slight smoke coming out of the vents. If I turn it to 5, heavy smoke starts pouring in and after a few seconds the fan slows way down. I can go back to 2 and all is well again. I haven't kept it on 4 or 5 for more than a few seconds for fear of starting a wire fire. What could be causing this? Resistor? Blower motor? What wire could be burning, if a wire at all?
Thanks for you help!
