Thread: 2001 grand prix gp bleed abs?
Results 1 to 4 of 4
  1. #1 2001 grand prix gp bleed abs?
    Apr 2014
    CT
    I did a search didn't see what I was looking for. brake system was run dry. the abs was removed from car to change brake lines. Will the abs solenoids need to be bled or can I get away with a traditional bleed?
  2. #2 Re: 2001 grand prix gp bleed abs?
    if the master went dry you'll have to bleed it. on its own.
    the abs, it should pump fluid like a normal brake fluid flush.
  3. #3 Re: 2001 grand prix gp bleed abs?
    Apr 2014
    CT
    thanks the master did go dry but I primed it. I started doing it the conventional way and had a hard time until I got the master primed. I'm not done yet but my abs and tcs lights are on so I'm guessing I have a wheel speed sensor issue too
  4. #4 Re: 2001 grand prix gp bleed abs?
    to bleed the master. other then taking it off and bench bleeding it.
    you can pump the pedal like you would for a caliper, hold the pedal, then crack the line nut on the master, you will hear air spit out, do each line a few times till its just brake fluid forcing out the nut.
    i like to put the wrench on the line nut, then wrap a rag around the line nut to keep fluid from spraying all over, or in your eyes.
  1. how to bleed the breaks on a 04 grand prix
    By DirtDog in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2012, 04:03 PM
  2. 2001 grand prix gtp help
    By Mandy Picknell in forum General Grand Prix Discussion
    Last Post: 04-18-2012, 05:41 AM
  3. is the 1999 grand am stereo the same as a 2001 grand prix gt?
    By llinziee in forum Audio, Security & Visual Electronics
    Last Post: 07-06-2011, 03:51 PM
  4. Hello im new i own a 2001 grand prix gt
    By Jesse1 in forum Introductions/Noob Questions
    Last Post: 10-14-2009, 03:46 PM
