Thread: Intake Insert?
Results 1 to 12 of 12
  1. #1 Intake Insert?
    Mar 2014
    SE PA
    I wasn't able to find an answer to this - basically, I know that the HV3 is a nice mod because it frees up some room around the intake runners but I was wondering, what would happen if you just ran without an intake insert at all? Would there be a huge drop in low end power/not big enough boost in top end to justify it?
  2. #2 Re: Intake Insert?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    The insert is there to smoothly direct air into the cylinders. The stock insert forms long swooping runners that allow air to reach a high velocity and ram into the cylinder like a cheap hooker with daddy issues. This is good for low end torque. Problem is that it also adds alot of plastic into the manifold that ends up restricting airflow at high rpms (One of the runners even obstructs the throttlebody). The HV3 is a compromise between nice short runners / high rpm power and long runners / low end grunt. Its a good upgrade in my book.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  3. #3 Re: Intake Insert?
    Pull it out and find out. Only takes a few min
  4. #4 Re: Intake Insert?
    Or...cut the runners down and have a DIY HV3
  5. #5 Re: Intake Insert?
    Florida Tuner Z34Phoenix's Avatar
    Florida
    now there's "thinkin with your dipstick!"
    96 Z34 (RIP LQ1 14.81@92.3) L36 Swap 14.9@91.5 www.cardomain.com/id/z34phoenix
    Topswap: P&P All,Si Valves,L76's,LW Pushrods,SD's,DHP PT PB 13.91@99.8
  6. #6 Re: Intake Insert?
    I break stuff selliott's Avatar
    Kansas City
    Sounds like a diy write up bill
  7. #7 Re: Intake Insert?
    hangover park IL
    id ditch the insert and spend 20 minutes with a die grinder to bell mouth the LIM ports and spend the 130$ on a hooker
    ~James~ Psychotic Gearhead
  8. #8 Re: Intake Insert?
    Quote Originally Posted by Turbocharged400sbc View Post
    James..
    You need a steadier hand. Your hooker seems reasonably priced, what's that include. lol
  9. #9 Re: Intake Insert?
    hangover park IL
    usually about 25 miles if we need a flatbed....
  10. #10 Re: Intake Insert?
    Mar 2014
    SE PA
    I would just buy the HV3 but I can't justify spending almost $200 on a molded piece of plastic... Anyone know just how much I'd have to cut off the stock insert to get it to be HV3-ish?
  11. #11 Re: Intake Insert?
    Apr 2011
    South Dakota
    Only problem I see with just cutting is that you still have tons of sharp turns and walls inside the plenum then which will effect flow.
    I love Decker<3
  12. #12 Re: Intake Insert?
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    If you try it i'd be interested to see how it works out
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  1. HV3 High Velocity Intake Insert
    By Jtiger360 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2015, 01:17 PM
  2. high velocity intake insert
    By RyanL in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2010, 10:16 PM
  3. HV3 High Velocity intake insert
    By Kerker48 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2009, 12:10 PM
