Thread: Anyone running ZZP light weight battery?
Results 1 to 5 of 5
  1. #1 Anyone running ZZP light weight battery?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    How'd you like it? Looks like it's rated at 14.4V.... Is that normal? Will I have any issues if I run this?
    Thanks!
  2. #2 Re: Anyone running ZZP light weight battery?
    Feb 2014
    Ky
    I ran a similiar genesis battery in my lt1 TA for 2 years no problem. Still in the car as far as I know. As it was a street strip car I did tricle it if I knew I wasnt gonna drive it for several days just in case.
  3. #3 Re: Anyone running ZZP light weight battery?
    Feb 2014
    Ky
    Basically a motorcycle battery .12 lbs vs 52lb optima . Was the difference in pulling one front tire on launch to both fronts in my TA. Havent looked at the price but I sure you can find one cheaper if you look around. But as far as weight saving well worth it for that. Zach I believe ran one in his car (xpzspeed) the one in the for sale section
  4. #4 Re: Anyone running ZZP light weight battery?
    Mar 2014
    Cincinnati, OH
    Thanks, and good to hear. I have always been a fan of weight savings. If there aren't any potential issues from a voltage standpoint, I will likely go with it.
  5. #5 Re: Anyone running ZZP light weight battery?
    Feb 2014
    Ky
    That would be left up to your alternator. I was a skeptic till I used one. worked just like my optima, basically all it has to do is start the car. The alternator does the rest .
  1. Constant Electrical Drain Running Down The Battery
    By falcongt in forum General Tech Discussion
    Last Post: 11-06-2017, 07:09 PM
  2. Replaced battery now running poorly.
    By StainedBedSheets in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2012, 07:37 PM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Battery Light
    By awq134 in forum Introductions/Noob Questions
    Last Post: 04-29-2009, 12:17 PM
  5. light weight wheels
    By 99prixgt in forum Tires & Wheels
    Last Post: 04-04-2009, 09:35 PM
