Thread: AC cold on passenger side, not drivers. Help!
Results 1 to 5 of 5
  1. #1 AC cold on passenger side, not drivers. Help!
    Jul 2013
    United States
    I own a 1999 gtp. It has the dual climate control function and I noticed last summer that the driver's side will no longer blow cold air, only hot. The passenger side, on the other hand, blows cold air. Any help on what this might be? I was looking around online and I think it may be the heater blend door and/orthe heater blend door actuator, but I'm not entirely sure.
    Thanks
  2. #2 Re: AC cold on passenger side, not drivers. Help!
    Never Never Land
    You got it. Blend door or actuator is most likely the culprit. This isn't specific to dual climate system. The regular 3 knob systems can have these same syptoms as well, just an FYI.
    I went to replace the actuator on mine and discovered it had already been done once before. Mine is still cold on the driverside, just not as cold as the pass side is. My problem is the door doesn't seal. I can stick my hand around the door and feel air coming out, so that's something to check as well.
  3. #3 Re: AC cold on passenger side, not drivers. Help!
    Jul 2013
    United States
    Awesome, thanks for the help!
  4. #4 Re: AC cold on passenger side, not drivers. Help!
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Not to thread jack, but I am having the exact same issue, except opposite sides (hot passenger, cold driver). Where are these doors located??
  5. #5 Re: AC cold on passenger side, not drivers. Help!
    Jul 2013
    United States
    I found this on a different thread, but this website has all the info needed for repairs. If you start the search (once you enter your car info) with: Temperature Actuator Replacement that should get you going. Here's the link to the thread:
    http://www.grandprixforums.net/threa...u-name-it-FREE
  1. AC Air vents - Hot one drivers side - cold on passenger
    By OCGP in forum General Grand Prix Discussion
    Last Post: 07-02-2013, 04:26 PM
  2. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  3. '04 GTP Comp G - Blower/ HVAC issue / Hot Drivers Cold Passenger
    By KKli23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 08:32 PM
  4. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  5. Heater blowing cold on drivers side
    By sophie in forum Introductions/Noob Questions
    Last Post: 11-03-2010, 08:00 PM
