Thread: A little wheel wiggle
Results 1 to 20 of 27
  1. #1 A little wheel wiggle
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    Hi all.
    I've noticed an noise increasing in volume over the last few weeks. I suspected it was a wheel bearing as I've heard this noise before. I jacked the car up and gave it a little wiggle and found that the left front tire had some movement and a small clunk on the top/bottom wiggle. Not as much, but still some movement on the left/right wiggle. I had my wife shake the tire while I put my hand on the tierod and ball joints and the axle to be sure it wasn't one of these. I was all set to order a new hub/bearing when I just had a thought. There is no upper ball joint, but I think there is a bearing plate on top of the strut. Before I jack the car up again, is there anything I should watch for in that regard? The noise was a rotational, speed-based sound that reminds me of bad wheel bearings, but before I plunk down $100 for a moog hub I just like to find a second opinion.
    It's a 2004 GT, mostly original suspension. Some of these hubs were replaced under warranty 100K miles ago, but it's possible this one has 150K on it.
    Thanks.
  2. #2 Re: A little wheel wiggle
    jack the wheel up again then push pull the top of the tire, but this time watch the rotor. if its moving inside the caliper the hub is bad.
  3. #3 Re: A little wheel wiggle
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I'm putting money on bad bearing with top/bottom movement, you should try Timkin hubs, cheaper and lots of people here use them and had good luck with them. If your tie rod ends are stock might as well throw new ones on the list even more so if you are getting left/right movement.
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: A little wheel wiggle
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    This is DetroitAxle. I bought my frt axles,struts and bearings from them. Their parent company is Timken.
    http://www.ebay.com/itm/2-Front-Olds...baf4a2&vxp=mtr
  5. #5 Re: A little wheel wiggle
    Dec 2010
    ATL,Georgia
    Detroit Axles are good hubs.. was skeptical at first but I am very pleased with them.. they are solid hubs and beefy
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  6. #6 A little wheel wiggle
    Mercer, Pa
    $76 for 2 bearings and tie rods!
    You get what you pay for! I'd be afraid to go over 65 mph on them. If timken wanted there name associated with them they would put timken on them. They are just importing cheap cheap Chinese parts and cashing in on people willing to replace them multiple times to save a buck.
  7. #7 Re: A little wheel wiggle
    Sep 2013
    tulsa okla
    Detroit
  8. #8 Re: A little wheel wiggle
    Eau Claire, WI
    That's a great idea, thanks. I did feel the rotor to make sure it was moving with the rim but didn't think of the caliper.
    As for the cost, I'm not worried about the $100 just about wasting it if the hub isn't. My problem. I might check out Timken if it's locally available. I order parts here and there but I really like the safety net of having a local place to return to if something isn't right.
  9. #9 Re: A little wheel wiggle
    Apr 2012
    Dayton, OH
    Well I would do the Hubs anyway if you have extra money laying around, at least from what I can gather its not if it goes bad but when.
    2012 F150 STX
  10. #10 Re: A little wheel wiggle
    SWPA
    Quote Originally Posted by lewis1952 View Post
    Detroit
    Just because the company is located in Detroit does not mean the parts are made in Detroit. They are a DISTRIBUTER, which means they sell parts made elsewhere.
    Read reviews online about Detroit Axle. There are several that fail within 10k miles.
  11. #11 Re: A little wheel wiggle
    Sep 2013
    tulsa okla
    If you want to spend money for a name go ahead I was just giving the another option. All parts made and distributed in the US have to meet SASE standards. Detroit Axle has been around 70 yrs. My god do what ya want. Some people would b#$ch if they were hung with a new rope.
  12. #12 Re: A little wheel wiggle
    Arizona
    I have GMB bearings now 32 bucks a piece off amazon there quieter than timkens ever were. And came with new bolts and harness clips.
    I'm over the whole USA but really made in China crap. Its all the same now and days might as well save some money.
  13. #13 Re: A little wheel wiggle
    Mercer, Pa
    Who said Timken, Moog SKF are made in USA?
  14. #14 Re: A little wheel wiggle
    Quote Originally Posted by 91parkave View Post
    the reviews make me want to run from gmb. if i could run faster i would. http://www.amazon.com/GMB-730-0093-W...ews/B0041MCGT6
  15. #15 Re: A little wheel wiggle
    Arizona
    Quote Originally Posted by sseilmnop View Post
    its not a reference to you, if that's how you took it.
    Only time will tell man, theyv done great on the highway and daily driver duty so I have to give them thumbs up for now.
  16. #16 Re: A little wheel wiggle
    Mercer, Pa
    Honest I don't make wheel bearings for a living. The good ones are still coming from low cost suppliers it just that Timken/Moog/SKF are guaranteeing the quality is there. They back it up with a 3 year warranty.
  17. #17 A little wheel wiggle
    Mercer, Pa
    I ran cheap bearings one time. Bought them from ZZP, and replaced right twice and left once. ZZP sells them with 30 or 90 day warranty now not a year. I made the mistake of changing both sides at once.
    I've owned Bonneville's for 10 years now. Timken's have never failed.
  18. #18 Re: A little wheel wiggle
    Eau Claire, WI
    I've come to trust Moog (made in Korea) for quality. It's not that I have $100 to burn, but that I don't take a chance on suspension parts. For example, I just had to replace a wheel bearing on my truck. I assume it was a factory wheel bearing. I heard a small intermittent noise, but didn't give it much though for a while. After a few days of driving it, the noise suddenly was louder, and more prominent. I jacked the truck up and wiggled a wheel just like my car. I could not believe the play I had in that bearing. It was about 2 inches at the outer edges of the tires. Much more damage than that, and the bearing could have just separated and come apart. If that happened at 70 MPH... I just don't play with that risk. I'll use a generic relay, I'll take the cheaper water pump, but not the safety critical part.
    Thanks again for the tip Scottydogs, that was very definitive. I suck my finger tip between the rotor and the caliper and wiggled the tire up/down, and could plainly feel the rotor moving independent of the knuckle.
    Side question. Does anyone happen to know the hub nut size and torque specs?
  19. #19 Re: A little wheel wiggle
    Apr 2012
    Dayton, OH
    118ft/lb and 36mm
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
  20. #20 Re: A little wheel wiggle
    stock is a 34 mm, new axles come with a 36 mm nut. tq is 118.
    if you dont have a 34 mm but have a 36 mm, the 36 will work on the 34 mm nut. been there done that. i find it best to put the spare tire on use like 2 lugs, then lower the wheel to the ground, then break the axle nut free.
    if you have f body brakes you need to take the brakes off first to get the spare on, but they need to come off any ways so no big deal really.
  1. Passenger wheel and wheel area hot and smeels of hot metal
    By TheInterloper in forum General Tech Discussion
    Last Post: 02-11-2014, 11:59 AM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. Got some wheel questions for you wheel guys
    By gtpeddie in forum Tires & Wheels
    Last Post: 09-22-2013, 07:07 PM
  4. Front wheel squeeks when wheel is straight.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 06-13-2011, 07:02 PM
  5. Steering wheel wiggle
    By Dallasneon in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2010, 11:38 AM
