Alright. Currently have a genV blower on a 1" short stack intercooler. Car was running perfectly with normal fuel trims, normal vacuum, no missfires, raced a 2012 evo and won last night with 4 people in the car.... You get the picture right?
Anyways today it fired up fine no issues drove to work and everything is happy as a clam, even got to show off to a coworker at a stoplight. Get off of work and the car is pulling 40%+ positive fuel trims at idle with normal ~5% trims under load. WOT fueling is still locking in at 11.5 no problems. As soon as I let it drop to idle the thing wants to stall until it can pull the fuel trims to 50% again. It will idle basically normal with some missfiring and not perfectly even rpms. Wideband is agreeing with the fuel trims more or less.
Things I have eliminated
-Its not o2 sensor wideband is showing that everything is leveling out at 14.7 like it should
-Its not the maf or maf scaler, car is just as retarded with or without it plugged it
-Its not the map sensor, the readings agree with my boost / vacuum gauge so its ok
-All of the vacuum lines are connected and not leaking, Tested by unhooking and plugging the three ports on top of the blower as well as the LIM port.
-Its not the retarded genv pcv system as far as I can tell. No vacuum is being pulled on the crankcase and im running a breather so I have all of the pcv related ports plugged
-Only CEL came on AFTER the problem started. System too lean bank 1. My response? No **** I can tell.
My guess is vacuum leak somewhere between the blower, intercooler, and lim. I tried watching the wideband output while spraying brake cleaner everywhere along the edges but didn't notice any spikes. Should I take the time to pull the blower / intercooler off in the parking lot or should I be looking elsewhere for my issue?
The current plan is to pop the rails blower and intercooler off and reseal with grey rtv. Shouldent take more then 2 hours. Currently is sealed with grey rtv and garlock gaskets. (My guess is everyone will say that's the problem right there)
