Thread: Wobble at high speeds
Results 1 to 2 of 2
  1. #1 Wobble at high speeds
    Jan 2014
    New jersey
    1999 grand prix gtp
    Once i hit 60 mph and above my car shakes as if im hitting multiple bumps but if i gradually turn at them speeds the shaking stops, it only happens when going in a straight line, it feels like its coming from the right side, maybe a bad tire? My sway bar is broke on the right side front but i Would not think thats the issue. Please let me know what to look for
  2. #2 Re: Wobble at high speeds
    rotate your tires front to back. if the front end stops shaking its a tire gone bad.
    you can also jack up the front tires and lugs tight, and see if you get play left and right if you push and pull the wheel. if you feel play the tie rod is bad.
  1. vibration at high speeds after lowering
    By des19 in forum General Grand Prix Discussion
    Last Post: 05-13-2013, 04:04 PM
  2. front end wobble
    By newmod in forum Brakes/Suspension/Chassis
    Last Post: 12-30-2011, 03:08 PM
  3. Got myself some wobble and need help
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2010, 08:05 PM
  4. 95 GP Shudder at High Speeds
    By TheDude in forum General Tech Discussion
    Last Post: 04-15-2010, 10:00 AM
  5. Boost lost at high speeds. Help?
    By pizzi22 in forum General Tech Discussion
    Last Post: 11-06-2009, 11:28 AM
