Thread: How to replace multi turning switch in 07 Grand Prix?
Results 1 to 5 of 5
  1. #1 How to replace multi turning switch in 07 Grand Prix?
    Jun 2012
    San Antonio
    Replacing the multi switch/turning signal and need advise. Anyone done it before? Do I disconnect the battery and pull out the air bag fuse first? Thanks!
  2. #2 Re: How to replace multi turning switch in 07 Grand Prix?
    Jun 2012
    San Antonio
    Anyone done this before?
  3. #3 Re: How to replace multi turning switch in 07 Grand Prix?
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    I have done this. Basically what you need is 90° ratcheting screwdriver a T-25 Torx bit and alot of patience. I didn't even mess with the airbag. The plastic shroud is the hardest part of the entire job. It really has to be muscled in and out it just uses alot of plastic clips with the shroud off you will see the switch there are 2 T-25 screws that hold it on. Once you have the screws removed pull out the switch and disconnect all 3 harnesses. Simply slide your finger nail or a screwdriver under the tab and give it a firm tug. It will come off. Once that is done repeat the steps backwards.
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  4. #4 Re: How to replace multi turning switch in 07 Grand Prix?
    Jun 2012
    San Antonio
    Should u remove the air bag fuse just in case?
  5. #5 Re: How to replace multi turning switch in 07 Grand Prix?
    Nov 2013
    Des Moines, IA
    Quote Originally Posted by elejes View Post
    You can if you would like. I did not remove it I was just extra careful with the harnesses ect
    2007GPGTSC
    " sad thing is "
  1. Replies: 4
    Last Post: 06-03-2013, 06:23 PM
  2. 1995 pontiac grand prix turning over but wont start.. help!
    By kdf401 in forum General Tech Discussion
    Last Post: 10-12-2012, 07:09 PM
  3. How To replace the taillights on a 04-08 Grand Prix
    By 1ATony in forum How To Write-Ups/Tech Tips
    Last Post: 01-26-2011, 09:28 AM
  4. Multi Function Switch
    By N8Dogg98 in forum General Tech Discussion
    Last Post: 09-30-2009, 02:48 AM
