Thread: Will comp g trans work in my 05 gtp
Results 1 to 8 of 8
  1. #1 Will comp g trans work in my 05 gtp
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Got a 05 gtp plain without paddle shift, and I found a 05 comp g trans for $200 out of a 04 or 05 gtp. Other than a tune would I need anything else? I just mainly want the 3.29 gears and not to mention the trans has only 60k miles on it 25k less miles than mine.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Will comp g trans work in my 05 gtp
    St. Louis
    I don't think so as the valve body is different as well IIRC.
  3. #3 Re: Will comp g trans work in my 05 gtp
    It will not be a direct swap.
    Gearing, valve body, paddle shift stuff would all be different. I don't think even a tune can work around not having the tap shift option. But I never dug super far into such a swap to read up on it.
  4. #4 Re: Will comp g trans work in my 05 gtp
    Dec 2012
    troll land
    Mebbe just grab a non hd from an 04 na monte ss?
  5. #5 Re: Will comp g trans work in my 05 gtp
    I've heard that it'll work but have no experience with it.
  6. #6 Re: Will comp g trans work in my 05 gtp
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Non sure if it would work but can you just get the gears from an n/a car and put them in your tranny? I'm not sure if they just change over but I'm sure someone on here can tell you
    I went NA when a whore left -$300 in my bank account.
  7. #7 Re: Will comp g trans work in my 05 gtp
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    You can make it work, but it's not easy.
    You need to removed the Valve Body, Channel Plate, and 4th gear clutches from your current trans, and swap them into the CompG Trans. Then you can tune for the 3.29 gears.
    I'm currently running a trans modded like this in my 04 GT for over a year with no issues.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  8. #8 Re: Will comp g trans work in my 05 gtp
    You only have 85k on your trans for all the work you'll have to do I wouldn't bother. 3.29s aren't anything to special.
    04 Comp G.
  1. Comp G an HD trans?
    By gotgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2012, 08:00 AM
  2. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  3. engine light and comp port dont work
    By 1999gpgt in forum General Tech Discussion
    Last Post: 09-29-2009, 06:21 AM
