Thread: fixing hud???
Results 1 to 14 of 14
Threaded View
  1. #9 Re: fixing hud???
    Fayetteville, AR
    I got ya covered. No superglue required. A guy over at GPONA had the same problem. It's a result of the mirror inside the HUD coming loose from the spring, and when you adjust the display up or down the spring and the mirror are the pieces inside the HUD which allow up and down adjustment of the HUD display. Hope that makes sense. Anyways, take a look at this write up, it should answer your question. HUD Repair Write-Up
  1. Need help fixing EGR code P0401!!!
    By grprx01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2022, 06:48 PM
  2. Fixing error code P0560
    By dowtrader in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2008, 08:23 AM
  3. Fixing error code P0560
    By dowtrader in forum General Tech Discussion
    Last Post: 07-18-2008, 12:12 AM
  4. Fixing leaking corner lights, through lamps.
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 04-21-2008, 09:39 PM
  5. Fixing a deep scratch/chip
    Last Post: 03-01-2008, 09:04 AM
