Thread: How to remove transmission cooling lines from the radiator
Results 1 to 8 of 8
  1. #1 How to remove transmission cooling lines from the radiator
    GT Level Member gpbastard's Avatar
    Florida
    I have an 01 GP SE 3.1 I'm going to be putting in a radiator pretty soon on this car and was wondering how to remove the transmission cooling lines from the radiator. I've heard that you need a GM quick disconnect tool for this. Has anyone else had any experience in getting these two lines off the radiator?
    gpbastard
  2. #2 Re: How to remove transmission cooling lines from the radiator
    Florida
    http://www.amazon.com/OTC-7937-Trans...pr_product_top
    Here's the tool I was talking about.
    gpbastard
  3. #3 Re: How to remove transmission cooling lines from the radiator
    GT Level Member mkyota1's Avatar
    Daytona, florida
    That tool works well on some cars. It did not have enough clearance to use on my grand prix. There is a little metal wire clip that keeps the line from pulling out of the fitting. Once you pull back the plastic cover that is over it you can carefully remove it using a pick. Once removed the line will pull out with a little twisting and pulling.
  4. #4 Re: How to remove transmission cooling lines from the radiator
    Florida
    Quote Originally Posted by mkyota1 View Post
    Thanks for the info. I won't buy the tool. It's like 20 bucks..haha
    gpbastard
  5. #5 Re: How to remove transmission cooling lines from the radiator
    I call them jesus clips, because when you drop one you'll say "jesus christ where did it go".
  6. #6 Re: How to remove transmission cooling lines from the radiator
    Florida
    I hear you. I lost my favorite spark plug socket in the front bumper area and never did find it..
    gpbastard
  7. #7 Re: How to remove transmission cooling lines from the radiator
    Daytona, florida
    No problem man. You dont need it. Just be careful not to lose them and you will be fine.
  8. #8 Re: How to remove transmission cooling lines from the radiator
    Donating Users timboku's Avatar
    Montgomery, IL
    Ive lost many of.those..they sell.them at autozone in the HELP section..just it case..cause once it flys away its gone..
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. Leaking transmission cooling lines
    By Boarderx3120 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-03-2013, 12:11 PM
  2. Overheating with alot of pressure in cooling lines.
    By Gizmo669 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2012, 12:31 AM
  3. Transmission cooling lines...which one is pressure?
    By Tea Time in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2012, 09:58 AM
  4. transmission cooling lines
    By chancinit666 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2010, 12:46 PM
  5. Transmission lines to radiator
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2008, 10:45 PM
