Thread: Transmission cooling lines...which one is pressure?
Results 1 to 2 of 2
  1. #1 Transmission cooling lines...which one is pressure?
    GT Level Member Tea Time's Avatar
    New Brunswick
    k fellas....'00 GTP . my tranny line started leaking the other day and i'm trying to find out which line it is but i'm not having much luck looking it up online. the line i need to replace is the line comin directly out of the bottom of the tranny and points straight to the ground. it then runs along the bottom of the rad and then threads into the bottom of the rad (not the upper line). is that line pressure or return? i ordered a line for an '00 GTP the other day and when it got here, all it had were the plastic clips on it. both my tranny and rad are threaded and i'm having a hard time getting the right line from the dealer. the '97 lines are threaded on both ends but they are a 2 piece line.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  2. #2 Re: Transmission cooling lines...which one is pressure?
    Portland Oregon
    Order a line for a 97-98 gtp or regal GS. They'll be the same. That's the pressure line
  1. Cooling system pressure test
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-15-2011, 02:41 PM
  2. Transmission lines help!
    By 2005GrandPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-21-2011, 07:26 AM
  3. transmission cooling lines
    By chancinit666 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2010, 12:46 PM
  4. Can someone take a pic of their transmission lines?
    By PurpleGuy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-08-2010, 01:17 PM
  5. Transmission Cooler Lines
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2010, 08:53 AM
