Thread: Ignition Switch & Harness keeps going bad
Results 1 to 14 of 14
  1. #1 Ignition Switch & Harness keeps going bad
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Both blinker lights on dash are on, as well as the high beam one. They won't turn off and I have no blinkers and the lights won't turn on by using the dial. Any ideas?
    edit: changed thread title. Replaced the ignition switch and harness with a new GM one and it fixed my issue, however, Tuesday it happened again. Blower motor resistor?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  2. #2 Re: Blinker Lights on Dash On
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    blinker fluid is low
  3. #3 Re: Blinker Lights on Dash On
    Nov 2012
    Frankenmuth, MI
    Quote Originally Posted by danomite02 View Post
    I just replaced that last week when I did my muffler bearings.
  4. #4 Re: Blinker Lights on Dash On
    Feb 2013
    37.295091, -121.930053
    it must be your headlight fluid need changing.
    i think it may be the steering column harness has gone nuts on ya
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Blinker Lights on Dash On
    being that the fluid loss jokes are out of the way. lol
    could be the multi switch aka the stick you move to turn the blinkers on. or the ignition harness.
  6. #6 Re: Blinker Lights on Dash On
    Jul 2011
    CT
    What does it do if you put the hazards on?
    ^thats what i was thinkin scottydoggs(multifunction swi)
  7. #7 Re: Blinker Lights on Dash On
    Nov 2012
    Frankenmuth, MI
    The flashers don't do anything until I pull the key out. The same thing happened about a month ago, but it clicked off after about two minutes and never came back.
  8. #8 Re: Blinker Lights on Dash On
    Jul 2011
    CT
    that is bizarre. I remeber something like that happening back when i was a GM mechanic..... i think it was actually the flasher.... but brain farts prevent me from actually remembering LOL. Go to a jy and snatch a flasher module hahha
  9. #9 Re: Blinker Lights on Dash On
    Feb 2013
    and an ignition harness
  10. #10 Re: Blinker Lights on Dash On
    Nov 2012
    Frankenmuth, MI
    Thanks for the input everyone. Put a new harness and switch in it last night and all is well!
  11. #11 Re: Blinker Lights on Dash On
    Nov 2012
    Frankenmuth, MI
    Sorry to bring up an old thread, but this happened again. Must be a short somewhere further down the line?
  12. #12 Re: Blinker Lights on Dash On
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Ever checked if you were low on blinker fluid?
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  13. #13 Re: Ignition Switch & Harness keeps going bad
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Ever figure out if anything was actually damaged on the old harness? Maybe its further down the line but you jiggled it enough to make it work when you replaced the harness? I would personally guess the turn signal / brights switch.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  14. #14 Re: Ignition Switch & Harness keeps going bad
    SE Level Member Prixer97's Avatar
    Jul 2011
    Fargo, ND
    Im curious to. GM ign switches ftw
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  3. Blinker issues - How do I know if it's the blinker springs?
    By Paranoid in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2012, 05:05 PM
  4. dash lights abs and airbag lights flicker
    By reem98 in forum General Tech Discussion
    Last Post: 01-24-2012, 12:37 PM
  5. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
