Thread: Race Pellet Vs. Disconnecting IAT Sensor
Results 1 to 9 of 9
  1. #1 Race Pellet Vs. Disconnecting IAT Sensor
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    Is it the same thing? Or does the pellet actually change what the IAT is reading?
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Race Pellet Vs. Disconnecting IAT Sensor
    What is a race pellet?
  3. #3 Re: Race Pellet Vs. Disconnecting IAT Sensor
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    http://shop.zzperformance.com/store/...ce-Pellet.aspx
  4. #4 Re: Race Pellet Vs. Disconnecting IAT Sensor
    What a completely retarded mod.
  5. #5 Re: Race Pellet Vs. Disconnecting IAT Sensor
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    It works with the zzp pcm, when the pcm sees the "race pellet" is plugged in it adds 4* of timing.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  6. #6 Re: Race Pellet Vs. Disconnecting IAT Sensor
    But it also says you must run 100+ octane fuel.
    Just out of the blue adding 4 degree's of timing is stupid, someone could go from 16-17 to 20-21 in the snap of the finger and that just about as fast a piston chips and goodbye motor.
  7. #7 Re: Race Pellet Vs. Disconnecting IAT Sensor
    Nebraska
    This
  8. #8 Re: Race Pellet Vs. Disconnecting IAT Sensor
    Waukesha, WI
    zzp logic
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  9. #9 Re: Race Pellet Vs. Disconnecting IAT Sensor
    Feb 2009
    flintnasty MI
    Same deal but no check engine light with the resistor.
    It wont bomb a basic setup but it will make race gas work. knock sensors USUALLY work ok and they work better when the timing is jacked up 4 across all flow.
  1. Toggle Position Sensor put my car into permanent race mode
    By SeanP in forum General Tech Discussion
    Last Post: 07-12-2013, 08:01 AM
  2. Engine stumbles after disconnecting battery...
    By hambony in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2011, 08:32 PM
  3. ZZP Race Pellet & Happy Knob
    By 4boostin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2010, 02:33 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. 2 Race cars drag race
    By KawaFord in forum Off Topic Discussion
    Last Post: 09-06-2009, 02:11 AM
