Thread: Gtp Lim and supercharger tourqe specs and sequence
Results 1 to 6 of 6
  1. #1 Gtp Lim and supercharger tourqe specs and sequence
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    I need a pic or something for the torque specs and sequence for the lim and supercharger for my 99 gtp. I'm replacing the gaskets.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Gtp Lim and supercharger tourqe specs and sequence
    Florida
    LIM is 11ft lbs, S/C is 17ft lbs
    Can't find a pic for the S/C, but start with the center 4 in an X pattern, then do the outers. Make sure to double check each bolt, because as you tighten more, the first ones will be loose.
    Also, make sure the S/C spins by hand easily after torquing it, if not, loosen the bolts and retry.
  3. #3 Re: Gtp Lim and supercharger tourqe specs and sequence
    Florida
    Also, #5 isn't show, but it is the bolt just below #11 near the coolant elbow.
  4. #4 Re: Gtp Lim and supercharger tourqe specs and sequence
    stanford Ky
    Thanks I got it done. Not to bad of a job. Just got to replace some broken vacuum lines. Damn things was brittle as hell. Put new aluminum coolant elbows on, and changed the s/c oil while I was at it.
    99 gtp- sold
  5. #5 Re: Gtp Lim and supercharger tourqe specs and sequence
    Vacuum line is like $12 from the dealer or just make your own.. Personally I went the dealer route for as cheap as they are.
    04 Comp G.
  6. #6 Re: Gtp Lim and supercharger tourqe specs and sequence
    stanford Ky
    Yeah I'll probly just run by the dealer and get it. I like things original
    99 gtp- sold
  1. Head gaskets torque and sequence
    By Hono in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2013, 10:26 AM
  2. tourqe wrench for supercharger
    By 97RS in forum General Tech Discussion
    Last Post: 01-16-2011, 01:13 PM
  3. Gen V torque sequence problem
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2010, 05:04 PM
  4. porting supercharger specs please
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2009, 01:18 AM
  5. pics of powder coated tourqe stars
    By 1BlwnGTP in forum Visual/Body Modifications
    Last Post: 09-28-2009, 07:13 PM
