Thread: Front end clunking/grinding
Results 1 to 4 of 4
  1. #1 Front end clunking/grinding
    Jan 2014
    New jersey
    Hello i have a 1999 pontiac grand prix gtp, at first i got a slight clunking or grinding sound from the front end. not happening very often, recently it got worse, when i accelerate from a stop it grinds and clunks, after i pass 5-10 mph it stops. Also clunks when i brake sometimes. My front right side the sway bar bushings are not intact anymore and the bar isn't connected too anything on the right side but i dont think this is whats causing the problem. Any ideas? I dont think my motor mounts are shot, could it be exaust loose ?
  2. #2 Re: Front end clunking/grinding
    Arizona
    Fix you're sway bar man. More than likely your mounts are shot if youre guessing on their condition. While you're doing all that re tourqe your caliper bracket to knuckle bolts.
  3. #3 Re: Front end clunking/grinding
    Iowa
    Grinding noises generally tend to be wheel bearings. Clunks can be anything from control arms, sway bar bushings, bad struts, bad strut mounts. Replace your sway bar if its broke. Why were you not fixing it in the first place? lol
  4. #4 Re: Front end clunking/grinding
    GTP Level Member
    Aug 2012
    st louis park, MN
    Ummm, if something is clearly broken why not fix it? Stop by a shop; since your screename implies you are a girl, I'm sure they'll tell you all sorts of things that are wrong. Hopefully a few of those could be your actual culprit.
    If you got down far enough to see a broken sway bar why not look at the exhaust youself? Is it touching the ground? Grab it with your hand give it a wiggle, is it loose or what?
  1. Clunking from front and rear.
    By cameron92 in forum Brakes/Suspension/Chassis
    Last Post: 03-06-2014, 02:20 PM
  2. Clunking noise from front end
    By PrixieGirl69 in forum Engine
    Last Post: 01-06-2014, 11:20 AM
  3. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  4. Clunking from front end on smooth roads 2005 GXP
    By glss421 in forum 5.3L V8 (LS4)
    Last Post: 05-14-2010, 08:19 PM
  5. *Clunking Noise From Front Left*
    By CleanGP in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2009, 01:12 PM
