Thread: What are the long brackets above the battery and intake for?
Results 1 to 20 of 25
  1. #1 What are the long brackets above the battery and intake for?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    There are two long, identical brackets on either side of the engine bay. One above the battery, one above the intake box. What are these for? Okay to remove for clutter/weight savings?
  2. #2 Re: What are the long brackets above the battery and intake for?
    Add strength to the front end in crashes.
    I'm sure they also help push the movement up and away aswell in a front end crash.
  3. #3 Re: What are the long brackets above the battery and intake for?
    Mar 2014
    Cincinnati, OH
    Good point. I would think they might buckle the good up so that it doesn't go through the windshield as well possibly.. I can't decide if I should remove them..
  4. #4 Re: What are the long brackets above the battery and intake for?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I wouldn't, don't they give the front end some more rigidity or something I thought.
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: What are the long brackets above the battery and intake for?
    St. Louis
    Yep, leave em. Not only do they tie in the front end, but in the event of a crash they make the hood buckle upwards instead of shearing off your head.
  6. #6 Re: What are the long brackets above the battery and intake for?
    Florida
    ^ And if the insurance company sees that you removed them, they might not pay out since it's crash protection related.
  7. #7 Re: What are the long brackets above the battery and intake for?
    Mar 2014
    Cincinnati, OH
    Done deal. I'm leaving them in. Thanks guys
  8. #8 Re: What are the long brackets above the battery and intake for?
    May 2008
    Schuyler, NE
    Quote Originally Posted by FordMan77 View Post
    this
  9. #9 Re: What are the long brackets above the battery and intake for?
    Mar 2014
    Cincinnati, OH
    Yepp, that's what I figured. For hood buckling
  10. #10 Re: What are the long brackets above the battery and intake for?
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    They are most definitely not for hood buckling. If you look at them there is no crease or bend to make them want to buckle in any specific way. In fact I have seen multiple Wbody accidents where they buckled DOWN. The hood however has multiple design features that will cause it to bend upwards to avoid chopping at the drivers neck. They are for strength in the front end / handling purposes. Leave em alone unless you like a loose sloppy front end.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  11. #11 Re: What are the long brackets above the battery and intake for?
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  12. #12 Re: What are the long brackets above the battery and intake for?
    SWPA
    They are for strength and strength alone. The hood is designed to buckle and would buckle without them. If they were to make the hood buckle, then all cars would have them.
  13. #13 Re: What are the long brackets above the battery and intake for?
    Dec 2012
    troll land
    If you look at the bottom side of the hood youll see stamped creases, thats what makes the hood bend. And @smoke, that wasnt a direct head on. Look at the d side brace
  14. #14 Re: What are the long brackets above the battery and intake for?
    Florida
    Dem rims clean tho
  15. #15 Re: What are the long brackets above the battery and intake for?
    Mar 2014
    Cincinnati, OH
    Interesting.. I can see how, and I agree that they are likely not for hood buckling now. But wonder how a long thin piece of metal provides any additional structural rigidity to the front end.
  16. #16 Re: What are the long brackets above the battery and intake for?
    SWPA
    Because it boxes the corners. It's simple physics.
  17. #17 Re: What are the long brackets above the battery and intake for?
    Dec 2012
    troll land
    It doesnt add much but it does add reenforcement. Think of strut tower braces.
  18. #18 Re: What are the long brackets above the battery and intake for?
    Florida
    if you question it, loosen the bolts and take the car for a spin. you will hear them creaking and popping.
  19. #19 Re: What are the long brackets above the battery and intake for?
    May 2008
    Schuyler, NE
    Uhhhhhh....
  20. #20 Re: What are the long brackets above the battery and intake for?
    Feb 2010
    TN
    Any advantage with replaceing them with a heavier piece of metal?
  1. Headlight brackets
    By Kellson in forum General Grand Prix Discussion
    Last Post: 02-19-2014, 08:45 PM
  2. These brackets are cursed
    By vertebrate in forum General Tech Discussion
    Last Post: 08-28-2012, 02:51 PM
