Thread: Need advice on stuck plug wire boots
Results 1 to 12 of 12
  1. #1 Need advice on stuck plug wire boots
    Nov 2010
    Baltimore
    I have a plug wire that i can't get off at the plug. I can't even get that wire to turn either by twisting it at the boot. Over the years i've destroyed perfectly good wires trying to get them off by inadvertently yanking them straight out the boot. What's really making it difficult is those damn heat shields are in the way making it impossible to get a good grip. Those heat shields aren't really necessary are they?
  2. #2 Re: Need advice on stuck plug wire boots
    Florida
    No, the shields are not.
    Anytime they have gotten stuck on me, I've gotten a pair of pliers and wedged them between the head and the plug wire boot, and used a quick popping motion to get them loose. All else fails, tear the ***** off and get a replacement set, and be sure to use some plug grease.
  3. #3 Re: Need advice on stuck plug wire boots
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Pliers. Lots of twisting and turning/yanking.
    You can even buy Spark Plug Boot Remover tools as well. Most of your auto parts store should carry them.
  4. #4 Re: Need advice on stuck plug wire boots
    Florida
    Those usually only end up leaving you with busted knuckles and a still stuck on boot. They're great if the boots are only sort of on there, but as soon as they are stuck, it's a no go.
  5. #5 Re: Need advice on stuck plug wire boots
    Jun 2011
    Not if you wear actual mechanic gloves, like I do.
  6. #6 Re: Need advice on stuck plug wire boots
    Florida
    Not if you wear actual sissy gloves and a frilly skirt, like I do.
    Fixed.
  7. #7 Re: Need advice on stuck plug wire boots
    Jun 2011
    Fixed.
    I appreciate the fix.
    I only wear gloves when I'm tugging on something, knowing i'm about to bust my hand. The gloves come on and off non-stop.
  8. #8 Re: Need advice on stuck plug wire boots
    Dec 2012
    Where 4T65E's were born
    I do the same, well after I ripped mine off... Mine would turn but the metal clip was on that spark plug so tight. (aftermarket wires) From now on I feel where that clip is exactly and get the pliers right on it so it doesn't rip off. Assuming the heat shields aren't there, well if they were I'd bend them up and just remove them and reinstall without it.
    +1 on the spark plug wire grease aka dielectric grease, silicone grease
    Sold.
  9. #9 Re: Need advice on stuck plug wire boots
    Nov 2010
    Baltimore
    What's also making it difficult is the wires are in the back, #2 and #4. Plus those wires aren't that old and i really don't want to **** them up. I used silicone grease when i put them on but obviously it wasn't enough.
  10. #10 Re: Need advice on stuck plug wire boots
    Florida
    You might be able to get a wide straight-slot in there, rest it on the top of the spark plug, and try to pop it loose.
  11. #11 Re: Need advice on stuck plug wire boots
    Nov 2011
    NY
    Gloves? No way... There's no GLOVES in mechanical work! What's the world coming to?
  1. PRJ spark plug wire set??
    By TheManInBlack in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2013, 10:21 PM
  2. stuck plug<<<
    By Alsafi92 in forum 5.3L V8 (LS4)
    Last Post: 03-16-2013, 01:42 AM
  3. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  4. Question about spark plug boots...
    By loopy smurf in forum General Grand Prix Discussion
    Last Post: 11-19-2012, 11:17 AM
