Thread: Need advice on stuck plug wire boots
Results 1 to 12 of 12
  1. #1 Re: Need advice on stuck plug wire boots
    Florida
    Pliers. Lots of twisting and turning/yanking.
    You can even buy Spark Plug Boot Remover tools as well. Most of your auto parts store should carry them.
    Those usually only end up leaving you with busted knuckles and a still stuck on boot. They're great if the boots are only sort of on there, but as soon as they are stuck, it's a no go.
  2. #2 Re: Need advice on stuck plug wire boots
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Not if you wear actual mechanic gloves, like I do.
  3. #3 Re: Need advice on stuck plug wire boots
    Florida
    Not if you wear actual sissy gloves and a frilly skirt, like I do.
    Fixed.
  4. #4 Re: Need advice on stuck plug wire boots
    Jun 2011
    Fixed.
    I appreciate the fix.
    I only wear gloves when I'm tugging on something, knowing i'm about to bust my hand. The gloves come on and off non-stop.
  5. #5 Re: Need advice on stuck plug wire boots
    Florida
    I only wear gloves when I'm tugging on something, knowing i'm about to bust on and off non-stop.
    I bet
  1. PRJ spark plug wire set??
    By TheManInBlack in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2013, 10:21 PM
  2. stuck plug<<<
    By Alsafi92 in forum 5.3L V8 (LS4)
    Last Post: 03-16-2013, 01:42 AM
  3. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  4. Question about spark plug boots...
    By loopy smurf in forum General Grand Prix Discussion
    Last Post: 11-19-2012, 11:17 AM
