Thread: tired of not having any heat
Results 1 to 9 of 9
  1. #1 tired of not having any heat
    May 2008
    98 grand prix gt has no heat. Temp gauge during the summer runs hot around 200-220 but these last 2 months of frigid weather the gauge is lucky to even budge more than a couple degrees. Heater hoses feel warm but not burning hot. Blows cold air no matter what. Any ideas? Im tired of being cold. I was kind of thinking the thermostat might be stuck open?
  2. #2 Re: tired of not having any heat
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    If you never see the temp gauge move probably fubar tstat.
    Sent from my Galaxy Tab 3
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: tired of not having any heat
    Feb 2013
    37.295091, -121.930053
    Your heater core could be clogged try a back flush on it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: tired of not having any heat
    pop a new 195 t stat in, and flush the core. bleed the system and you should be good.
    if the t stat is stuck open it will be open when you take it out, thats how most fail these days (open) so you dont over heat.
  5. #5 Re: tired of not having any heat
    Jun 2012
    south haven mi
    Most of the cars I have worked on will have heat for a short time and the dexsludge will clog it back up even after flushing.I usually use a chemical to clean the heater core, poured directly in and blow it out with the air hose very slow at first until most of the liquid is gone.I do this both ways a couple times and then the same with water.To clean the whole system I use TSP or dishwasher magic which is 75% citric acid.The same ingredient as the over the counter flushes but a much higher content.
  6. #6 Re: tired of not having any heat
    Apr 2012
    Goderich, Ontario
    Believe it or not, toilet bowl cleaner works well too, and is quite cheep.
    -Paul Walker
  7. #7 Re: tired of not having any heat
    i want to see the tidy bowl man make it through a water pump lol
  8. #8 Re: tired of not having any heat
    Jun 2012
    south haven mi
    Yeah I was going to say that but didn't want to get blazed lol.I actually use the works toilet bowl cleaner right in the heater core. Its acid so be careful blowing it thru I wrap a shop towel or two around the hose.
  9. #9 Re: tired of not having any heat
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Dont muck with the heater core until you fix your tstat. Its literally a 5 minute 5$ job to change on these engines. Then test for heat. If you slip up and crack your heater core your gonna be a sad panda. Leave it alone until you know its not the tstat.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. Tired of fixing everything
    By nickgpgt in forum The Rant Forum
    Last Post: 04-15-2013, 01:11 PM
  2. Getting tired of this...
    By Mr Chill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2011, 08:18 PM
  3. tired of gtp
    By 2003 gtp in forum General Tech Discussion
    Last Post: 05-02-2011, 09:33 AM
  4. Tired of the FWD
    By GreyGhost in forum The Rant Forum
    Last Post: 07-03-2010, 04:06 AM
  5. Getting Tired of School
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 02-04-2010, 06:17 PM
