Thread: 1998 GTP electrical problem
Results 1 to 3 of 3
  1. #1 1998 GTP electrical problem
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    So about a year ago my dad purchased a 1998 2 door GTP with about 135k. The car drove fine but not perfect and he wanted me to do a LIM job so he towed it to me from El Paso TX to Chandler AZ. I had the car for about 4 months after that, I worked and replaced anything and everything I could see wrong with it.
    Well after the LIM job the car started to bog under acceleration. ALL vacuum hoses where replaced and couldnt see a leak. I decided to redo the LIM job and still after that it bogged. The biggest problem we noticed was that the car's headlight flickered when turned on and the car had problems staying on at night when headlights where turned on.
    So I have a feeling I have a short somewhere, before I took everything apart I removed a aftermarket alarm and a "performance chip" dont know if that is the problem. I would like to get this problem fixed so I could get my dad off my back . I would appreciate any help thanks!
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  2. #2 Re: 1998 GTP electrical problem
    St. Louis
    Check and clean all battery cables and grounds. Also check the backside of the undehood fuse block for corrosion as it can hide there and cause strange issues. Also might want to have the alternator checked out. Could be getting weak and not able to keep up w/ the demand.
  3. #3 Re: 1998 GTP electrical problem
    Jan 2009
    Will have all that check out thanks
    Sent from my LG-D959 using Tapatalk
  1. Electrical problem
    By 2000 in forum General Grand Prix Discussion
    Last Post: 06-12-2013, 06:02 AM
  2. electrical problem
    By josh88 in forum Audio, Security & Visual Electronics
    Last Post: 09-29-2012, 12:02 AM
  3. Electrical problem?
    By lucyboop in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 05:13 AM
  4. 04 GTP Electrical problem
    By victorallen in forum General Tech Discussion
    Last Post: 04-20-2012, 05:29 AM
  5. Electrical problem
    By rocket69GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 10:29 AM
