Thread: Where to tap vacuum line into manifold for boost gauge?
Results 1 to 10 of 10
  1. #1 Where to tap vacuum line into manifold for boost gauge?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Anyone have any pictures of where/what they used to supply vacuum/boost pressure to their boost gauge?
    Did you T into an existing vacuum port?
    Thanks in advance
  2. #2 Re: Where to tap vacuum line into manifold for boost gauge?
    Mar 2012
    NC
    T into the line going to the fuel pressure regulator as it needs to see vacuum/boost as well.
  3. #3 Re: Where to tap vacuum line into manifold for boost gauge?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Right b4 the map sensor along the firewall put a T in. That's where mine is and I get accurate readings.
  4. #4 Re: Where to tap vacuum line into manifold for boost gauge?
    Mar 2014
    Cincinnati, OH
    Thanks guys!
  5. #5 Re: Where to tap vacuum line into manifold for boost gauge?
    Mar 2014
    Cincinnati, OH
    Anyone have a picture of their setup by chance?
  6. #6 Re: Where to tap vacuum line into manifold for boost gauge?
    go to advance auto, they sell these little white T's, and a foot of vac line. cut the stock plastic line that comes from under the snout to the back of the engine, push a 2 inch long piece of vac line on the cut ends of the stock line, then put the t in the middle. then the boost gauge off the open port on the T.
  7. #7 Re: Where to tap vacuum line into manifold for boost gauge?
    Mar 2014
    Cincinnati, OH
    Good deal, have purchased and used those white T's before from Autozone. I saw another thread about where to route the vacuum line through the firewall. Any good locations you'd recommend while we are on the topic?
  8. #8 Re: Where to tap vacuum line into manifold for boost gauge?
    find a grommet under the brake booster. you should be able to push it through with the wires that are there already. try to route the line with other wires along the firewall, small zip ties work well, this keeps the line safe from being burnt or broken.
  9. #9 Re: Where to tap vacuum line into manifold for boost gauge?
    It's too late now, but you coulda searched around and found atleast 50 threads on vacuum lines for boost gauges....
  10. #10 Re: Where to tap vacuum line into manifold for boost gauge?
    Mar 2014
    Cincinnati, OH
    Sounds like I have everything I need. Thanks for the responses. FiveFinger, I hear you. should have searched a bit before starting a new thread on a covered topic.
    Cheers
  1. Where to route vacuum line for boost gauge
    By K Kraziee in forum General Tech Discussion
    Last Post: 03-02-2014, 07:32 PM
  2. Vacuum Line/Boost Problem
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2010, 01:17 PM
  3. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 03:18 PM
  4. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:36 PM
  5. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
