Thread: Vacuum/boost line coming off blower
Results 1 to 3 of 3
  1. #1 Vacuum/boost line coming off blower
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Hey Guys,
    New to this forum but on my 3rd GTP. This one is stock besides the K&N setup I installed yesterday and the 160 t-stat. Looking to do some healthy mods down the road!
    My question is in regards to the vacuum/boost line located towards the inlet side of the blower. The small one between the master cylinder vacuum line and the boost bypass valve line. What does this lead to? Does the ECU read from this? Does the boost gauge on the dash read from this? Why do some owners cap that off and eliminate that line?
    Thanks for the help!
    Glad to join the forum
  2. #2 Re: Vacuum/boost line coming off blower
    St. Louis
    Not sure on the lines, but that 160* stat will not help you unless you are tuned for it. In fact, it may hurt mileage by not letting the temp come up fully. That and the fans are still set to come on at 210*.
  3. #3 Re: Vacuum/boost line coming off blower
    Mar 2014
    Cincinnati, OH
    I am having trouble with my temp sensor that I just put in so I decided to put in the 160 until I get a new sensor installed that functions correctly (makes me nervous to see my temps that high). I was under the impression that 160 would be worth it to reduce KR though? I also have a 180 that I can put in as well.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. Vacuum Line/Boost Problem
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2010, 01:17 PM
  3. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 03:18 PM
  4. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:36 PM
  5. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
