Thread: Broken front sway & alignment ? Also sway bar recommendations..
Results 1 to 12 of 12
  1. #1 Broken front sway & alignment ? Also sway bar recommendations..
    GT Level Member Exile's Avatar
    Chicago
    The mounting points for my front antisway bar have broken off at the seam, as typical. Definitely going to be replacing the bar in the next month or so. My question is: Can it be effectively aligned with the sway bar being in its current state? I know I really need a good alignment and I'm worried about destroying more tires with uneven wear. My rush for the alignment is due to the fact I just started a new job, which involves much more highway miles....again i don't wanna destroy my tires.
    Also, quick recommendations for the replacement bar? Got a rear GMPP antisway, should I match it in the front? Or switch to a Dorman or Impala bar? The front GMPP is $115 on WBS with endlinks which sounds good to me.
    Thanks
    2001 Black GTP Special Edition
    KYB Excel-G struts, Dorman & GMPP swaybars, Dorman/WBS trailing arms, K&N CAI, ZZP 3" DP, Thrush GP, all new calipers
    And the GP appropriate gas cap fender rust
  2. #2 Re: Broken front sway & alignment ? Also sway bar recommendations..
    sway bar shouldn't affect an alignment at all.
    find a dorman solid sway bar. it comes with all new hardware but buy new polly bushings for it, the bushing that come with it fail rather fast.
    the end links are holding up just fine so far.
  3. #3 Re: Broken front sway & alignment ? Also sway bar recommendations..
    Mar 2012
    NC
    Dorman front at Autozone is about $100.
  4. #4 Re: Broken front sway & alignment ? Also sway bar recommendations..
    Chicago
    Was just gonna ask where to source a Dorman bar from.
    ZZP has Progress solid front for $140... closer to $100 sounds better xD
  5. #5 Re: Broken front sway & alignment ? Also sway bar recommendations..
    Mar 2012
    NC
    They aren't calling it a Dorman but it is...http://www.autozone.com/autozone/par...8592_382630_0_
  6. #6 Re: Broken front sway & alignment ? Also sway bar recommendations..
    ebay, ive seen them for 70 shipped. need to look hard tho.
    local mine came with all hardware for 120 at napa.
  7. #7 Re: Broken front sway & alignment ? Also sway bar recommendations..
    Chicago
    Thanks for input guys.
    But I think Amazon is the winner...
    $105 total for Dorman front kit, upgraded Moog bushings, and upgrade Moog endlinks for $5 each.
    I regret not throwing a coat of paint on my rear bar, think I should bother? As far as rust prevention goes. Either way I'm sure it'll outlast my car.
    Anything tricky about the install ?
  8. #8 Re: Broken front sway & alignment ? Also sway bar recommendations..
    nice score, with 2 broken ends now the new bar will make it corner like a race car lol
    i drove with no sway bar for like 2 months, i know how bad it can be. new bar feels like a new car lol
  9. #9 Re: Broken front sway & alignment ? Also sway bar recommendations..
    Chicago
    Its actually really scary to drive fast right now. Must be a combination of bad alignment and broken sway. I will not exceed 75mph in it as is. Starts feeling really sloppy and "floaty", its scary.
  10. #10 Re: Broken front sway & alignment ? Also sway bar recommendations..
    tires screech around every turn too.
    be careful on the highway, the car can get away from you pretty easy. like you said floaty boat action.
  11. #11 Re: Broken front sway & alignment ? Also sway bar recommendations..
    Antioch, IL
    I drove over a year without a front sway bar, only scared me once when I went to pass the lady real fast I almost hit her. To install all I had to do was take off the driverside tie rod end. Putting the rubber things on then trying to tighten the 2 bolts while squishing the rubber piece was a pita for me and the air ratchet.
    2009 Challenger SRT8
    Expert at being gay.
  12. #12 Re: Broken front sway & alignment ? Also sway bar recommendations..
    GTP Level Member
    Aug 2012
    st louis park, MN
    I recently noticed my sway bar has some corrosion on these sway bar ends and I noticed the seam seemed to be starting to separate but not nearly as bad as the OP. I'm trying to track down a clunk in the front end and was wondering if the corroded sway bar could be the problem or unlikely?
    Also, how can I test the ball joints to see if they are bad?
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  1. 2002 gtp broken sway bar end link
    By OcalaGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-27-2014, 11:55 PM
  2. Broken Sway Bar Help
    By Konner27 in forum General Tech Discussion
    Last Post: 11-19-2013, 09:22 PM
  3. Broken sway bar
    By Madness in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2013, 06:59 AM
  4. ABS problem and a broken sway bar... Oh what a fun day
    By ronmexico in forum General Tech Discussion
    Last Post: 04-15-2012, 11:25 PM
  5. Sway bar broken
    By skibender in forum General Tech Discussion
    Last Post: 01-20-2011, 07:23 PM
