Thread: help me find my exhaust leak
Results 1 to 10 of 10
  1. #1 help me find my exhaust leak
    GT Level Member yzboy85's Avatar
    Dec 2013
    maine
    I've had a leak since putting on my new sd headers and I can't seem to figure out where it is. I put band clamps on all my joints, used felpro gaskets, and have gone back through inspecting, making sure everythings tight, tried some rtv on the vband when I thought that might be the culprit, replaced the catback flange (which was leaking as well but wasnt the source of the problem) but still the damn ticking noise persists..
    I'm pretty much out of ideas at this point, I've tried basically everything I could think of, the only spots I haven't really checked are manifolds and flex. I don't really see any evidence of leaking anywhere, though its hard to see the rear manifold and back of the crossover without rocking the engine forward. Being brand new headers id assume my flex would be fine. I was also told by a friend manifold leaks are really obvious, and I can't hear the leak at idle or low rpm, only when I get on the gas a bit, so I kind of ruled that out too, but who knows.
    so are there any tricks that could help me with trying to figure this out? any input that might help me find the problem is appreciated
    02 GTP Coupe - Jennifer
    SD headers, SLP Powerflo catback, 3.4, CAI, Shift Kit, GMPP Sway Bars, F-Body Brakes
  2. #2 Re: help me find my exhaust leak
    seafoam the engine, if you see smoke any where but the tail pipes thats your leak.
  3. #3 Re: help me find my exhaust leak
    Bingo!
    04 Comp G.
  4. #4 Re: help me find my exhaust leak
    GT Level Member aligater's Avatar
    london ontario canada
    Sry I stopped reading at felpro.....
  5. #5 Re: help me find my exhaust leak
    Dec 2013
    maine
    felpros are definitely better than the ones that come with the headers lol
  6. #6 Re: help me find my exhaust leak
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    Could be your flex that's ticking, replaced my SLP flex with a ZZP flex, problem solved.
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  7. #7 Re: help me find my exhaust leak
    Oem gaskets > all
    04 Comp G.
  8. #8 Re: help me find my exhaust leak
    Most likely the sound you hear is the flex tick from it being thin. I agree with the dual wall swap.
  9. #9 Re: help me find my exhaust leak
    Dec 2013
    maine
    Yeah I'm thinking it might be the flex that's ticking. If SLP flexs tick like that brand new then I would assume SDs would as well (to my understanding they're same design just cheaper materials)
  10. #10 Re: help me find my exhaust leak
    SE Level Member LHRxXD3adXx's Avatar
    Oct 2014
    Hey i have the same problem theres a leak somewhere but i only hear it when i step on the gas. If i try seafoam do i just spray in in one of the vacuum lines?
  1. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  2. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  4. HELP!! Cant find oil leak
    By quadracer960 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2010, 01:49 AM
  5. I smell coolant but can't find a leak 01 GP GTP
    By smooth01gtp in forum Introductions/Noob Questions
    Last Post: 02-16-2010, 07:06 AM
