Thread: Ngk plugs
Results 1 to 6 of 6
  1. #1 Ngk plugs
    Nov 2013
    FL
    http://www.ngksparkplugs.com/part_fi...uv/results.asp
    For a 1999 grand prix 3.8 k engine tech support at NGK recommend laser platinum vrs the laser iridium plugs for my car. See link above which states OE is iridium. Why are they showing iridium as OE when the car came with platinum ?
    I have called twice and gotten this answer from tech which was the same guy. Did not give a reason except that these were the plugs originally supplied to GM. Any one have experience with any of these 2 plugs. Or is there a site where I can get a better answer . The guy on the phone was not that friendly and seemed like he would rather be doing something else.
    Sorry if this question is redundant but spark plugs" in the search box does not bring up what I am looking for although its probably because I don't know how to search.
  2. #2 Re: Ngk plugs
    Never use platinum plugs in a 3800, ever. Our igntion system will eat them alive and you'll get issues later on.
    Buy AC delco 41-101 spark plugs if you are wanting direct replacements.
  3. #3 Re: Ngk plugs
    Nov 2013
    FL
    Thanks 5 finger. See great reviews on amazon. Was looking for dot on ground electrode because of double or weak spark system.
  4. #4 Re: Ngk plugs
    Feb 2010
    TN
    Listen to 5 fingers he's right
  5. #5 Re: Ngk plugs
    Feb 2014
    Beverly, MA
    I def agree with the no platinum plugs. always iridium plugs. Ive always heard the the NGK while great on performance, will burn out quicker than ac delco. Ive always wanted to use the NGK, however I dont want to change my plugs every year.
  6. #6 Re: Ngk plugs
    Nov 2013
    FL
    Thank you all. Took your advice and ordered the Delco iridium plugs. Received them today and you can see the insert platinum disk on the ground part of plug and the iridium tip looks narrow and gapped correctly. Fell these plugs are superior to originals in 1999.
  1. Platinum Plugs vs. Iridium Plugs
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 10-17-2012, 10:55 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. plugs
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-01-2009, 02:27 AM
  4. plugs?
    By banzai7 in forum General Tech Discussion
    Last Post: 07-12-2009, 06:05 PM
  5. plugs?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 12:32 PM
