Thread: modded 1.9's and 90lbs springs
Results 1 to 20 of 32
  1. #1 modded 1.9's and 90lbs springs
    Jul 2013
    adrian, mi
    im trying to get away with out pulling the heads on my gtp. now if i go with the modded 1.9's are 90lbs springs neccesary or are the stock ones fine? im assuming i have to upgrade the springs along with it. new hydraulic lifters and 7.00 push rods.
  2. #2 Re: modded 1.9's and 90lbs springs
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    #90 springs are reccommended.....Save yourself a lot of money and run the original lifters and pushrods. No need to upgrade those.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: modded 1.9's and 90lbs springs
    Dec 2010
    ATL,Georgia
    Like GMR said...Yes upgrade your springs, retainers, locks and seals..but keep the stock lifters and pushrods
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  4. #4 modded 1.9's and 90lbs springs
    and you also don't have to pull your heads for a rocker/spring install unless you don't have a decent compressor
    04 Comp G.
  5. #5 Re: modded 1.9's and 90lbs springs
    Jul 2013
    adrian, mi
    no compressor. already ordered the lifters and push rods to so money already spent. so if i dont have a way compress the spring i will have to pull the heads?
  6. #6 Re: modded 1.9's and 90lbs springs
    Apr 2011
    Columbus, OH
    Pulling heads is a bad idea.....Use spring compressor along with air compressor or use spring compressor and turn motor manually with a breaker bar to make the cylinder you're working on be at TDC.
    You'll have 3x the cost, head aches, and labor involved in pulling cylinder heads.
    Return the lifters and pushrods if you can....it's literally a waste of money.
  7. #7 Re: modded 1.9's and 90lbs springs
    gardner,mass
    What greg said return the lifters and push rods and invest in a compressor.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  8. #8 Re: modded 1.9's and 90lbs springs
    Jul 2013
    adrian, mi
    I didn't even think about making each cylinder tdc when I replace the springs. good idea. so no push rods or lifters? when is it a good idea to replace the lifters and rods then?
  9. #9 Re: modded 1.9's and 90lbs springs
    When you need too lol. Unless your lifters exploded or are ticking loudly (most 3800s have some lifter tick)
    04 Comp G.
  10. #10 Re: modded 1.9's and 90lbs springs
    Jul 2013
    adrian, mi
    alright thanks guys
  11. #11 Re: modded 1.9's and 90lbs springs
    You have the wrong length pushrods anyway. Stock is 7.05
  12. #12 Re: modded 1.9's and 90lbs springs
    Feb 2009
    flintnasty MI
    another trick to change valve springs is to feed rope into the spark plug hole when the piston is near the top to hold the valve closed.
  13. #13 Re: modded 1.9's and 90lbs springs
    gardner,mass
    I was gonna say this so you dont risk cracking a valve or piston but i prefer compressor
  14. #14 Re: modded 1.9's and 90lbs springs
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    ^^^Ive done this on my mustang motor, works well.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  15. #15 Re: modded 1.9's and 90lbs springs
    For what it's worth I ran stock springs on my old 98 gtp with modded 1.9's
  16. #16 Re: modded 1.9's and 90lbs springs
    Dec 2010
    ATL,Georgia
    ^ yes but what were you shifting at?
  17. #17 Re: modded 1.9's and 90lbs springs
    6000rpm
  18. #18 Re: modded 1.9's and 90lbs springs
    Jun 2012
    south haven mi
    What is everyone using for compressors I have an engine on a stand and I have a compressor for heads that are off but it wont work? I saw some ls1 compressors on ebay http://www.ebay.com/itm/LS1-LS2-LS3-...06be1e&vxp=mtr does anyone know if this would work?
  19. #19 Re: modded 1.9's and 90lbs springs
    Dec 2010
    ATL,Georgia
    Quote Originally Posted by jsnyder49090 View Post
    By compressor we mean air compressor to fill the cylinders with air in order to change the springs
  20. #20 Re: modded 1.9's and 90lbs springs
    Jun 2012
    south haven mi
    O my bad I meant valve spring compressor ..
  1. modded zzp 1.9s springs retainers lifters
    By byebye04 in forum For Sale - Parts
    Last Post: 11-14-2013, 01:14 PM
  2. WTB ; Modded retainers & #90 springs
    By WolvesSoulZ in forum Wanted To Buy - Parts
    Last Post: 06-14-2013, 10:15 AM
  3. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
