Thread: Squeaks in Interior
Results 1 to 6 of 6
  1. #1 Squeaks in Interior
    Mar 2013
    NW Iowa
    Hi, I have a 1999 Grand Prix GT and after just about a year of ownership I am noticing more squeaks coming from the plastic interior. Has anyone found ways to stop the squeaky interior?
  2. #2 Re: Squeaks in Interior
    HUDSON
    there is only one way to stop the squeaks, and that is to not drive the car.
  3. #3 Re: Squeaks in Interior
    Mar 2012
    NC
    Buy felt tape...remove offending trim...put tape on areas that could rub together, rattle, etc. and reinstall trim. Road test...repeat as needed. This is the only way I've found to fix it. And stick-on pieces of thin foam...that helped too for rattles.
  4. #4 Re: Squeaks in Interior
    having someone push on this or that panel while driving will narrow it down too. match books are a good wedge to help use as a temp stop squeak while searching too. hell ive used them forever in my 77 gmc, the glove box squealed and a book of matches wedged in the top corner shut it up.
  5. #5 Re: Squeaks in Interior
    Mar 2013
    NW Iowa
    Thanks, once it is warmer out I might have to try the tape and foam.
  6. #6 Re: Squeaks in Interior
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    You can also spray dry silicone on the areas that are rubbing together and squeaking. Often times you will find that areas where screws are used to hold panels tight, have simply loosened up some and making sure they are snug helps.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  1. suspension squeaks like old mattress (video)
    By Juanmiguel in forum Brakes/Suspension/Chassis
    Last Post: 10-01-2011, 09:11 PM
  2. Dorman Fornt Sway Bar Squeaks
    By Joe942 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2011, 07:06 AM
  3. squeaks over every bump
    By twoleos617 in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2009, 10:39 PM
  4. Power steering wheel squeaks
    By Viper in forum General Tech Discussion
    Last Post: 01-17-2009, 01:33 PM
  5. Front ends squeaks when steering...
    By brycemassey in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 06:15 PM
