Thread: Ajar driver side door erorr
Results 1 to 18 of 18
  1. #1 Re: Ajar driver side door erorr
    wow that sensors is in the door latch.......
    you'll need to take the inside door skin off, then if the bolts are on the inside remove them, and the linkage rodd to the door handles.
    if the bolts are on the out side life will be easier for sure as far as re aligning it so the door shuts and locks right. most of the time if you put the new part right were the old one was, (use a marker to out line the old one,) then remove it. everything should line up the first time.
  2. #2 Re: Ajar driver side door erorr
    Mar 2013
    Canada
    Okay so I guess that is the part I will be changing if it still says AJAR after I cleaned it and sprayed it. It did go off but came right back.
  1. Driver side door won't open
    By Paranoid in forum Visual/Body Modifications
    Last Post: 11-17-2013, 05:01 PM
  2. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  3. Driver's side door key
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-20-2009, 03:01 AM
