Thread: Smell of gas??
Results 1 to 17 of 17
  1. #1 Smell of gas??
    Mar 2012
    Cincinnati
    So I just picked up my 99 GTP a couple days ago. A lot of times when I walk up to the car, I get the hint of gas. Now I don't see the "rainbow" on the wet ground that you'd see if gas was leaking. But tonight I did smell it inside the car. Prev owner didn't say anything about changing fuel pump. I guess I'm going to have to check there first. Anyone else ever have this issue? Any ideas where to check?
    1999 Grand Prix GTP
    GXP front brakes, Comp G wheels, Dual HUD pod, Aeroforce Interceptor & boost gauge, GMPP front & rear strut brace, catless downpipe & resonator delete, homemade short ram intake w/ K&N filter
  2. #2 Re: Smell of gas??
    Feb 2013
    37.295091, -121.930053
    do you have the CEL on? i changed mine and the CEL came on. also remove the inspection plate in the trunk its 10mm bolts theres 7 of them.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Smell of gas??
    check the quick disconnects on the fuel rail on top of the supercharger. the O rings get old and they leak. you can change the O rings inside if they are leaking.
    they tend to leak after the car is turned off. and there will be a brown stain under the line if its leaking on the sc.
  4. #4 Re: Smell of gas??
    Mar 2012
    Cincinnati
    No CEL at all. I'll definitely check the o-rings tomorrow. Thanks for that suggestion.
    1999 Grand Prix GTP
  5. #5 Re: Smell of gas??
    Mar 2012
    NC
    Ahhh...Scotty stole my diagnosis! LOL
  6. #6 Re: Smell of gas??
    Quote Originally Posted by Sven Sexman View Post
    only because i lived through the exact same thing. bought the car kept smelling gas, found it wet and leaking after i shut the car off. nice brown stain on the sc from the gas leak.
    truth is i was worried it would burn after i walked away for the night.
  7. #7 Re: Smell of gas??
    Mar 2012
    Cincinnati
    Exactly my worry. And the fact that my daughter will be in this car and I don't want any sudden fires/explosions while I'm driving with her in it. lol
    1999 Grand Prix GTP
  8. #8 Re: Smell of gas??
    Mar 2012
    Cincinnati
    Well, I must have been jinxed after the talk of the CEL. It came on this morning on the way to work. Guess I'll be getting it scanned after work. I'll update you guys on what code(s) it's throwing.
    1999 Grand Prix GTP
  9. #9 Re: Smell of gas??
    Mar 2012
    Cincinnati
    Ok so I got the P0420 (cat innefective) code. So I'd say that's legit considering I have no cat. lol
    1999 Grand Prix GTP
  10. #10 Re: Smell of gas??
    Feb 2013
    if it dont have the CEL on then it aint no prix
  11. #11 Re: Smell of gas??
    I have that same code.
  12. #12 Re: Smell of gas??
    The Boss Iceman6669's Avatar
    Jun 2011
    I don't get that code with no cat... :-)
    2011 F-150 Yote powered
  13. #13 Re: Smell of gas??
    Me either
  14. #14 Re: Smell of gas??
    I won't soon.
    Sent from A Galaxy Far Far Away........
  15. #15 Re: Smell of gas??
    Mar 2012
    Cincinnati
    Well I just have to order the right part and I won't either. lol Anyone have one for sale? lol
    1999 Grand Prix GTP
  16. #16 Re: Smell of gas??
    you can try the fouler trick.
  17. #17 Re: Smell of gas??
    Mar 2012
    Cincinnati
    Well got it on a lift today. The prev owner jacked the fuel lines up that run between the pump and the filter. The connections have all been changed and they leak like friggin crazy. Of course GM doesn't make those lines anymore and no auto parts stores sell em. Heading to U Pull tomorrow to see if we can find some in good shape. if not, guess we have to "make" some lines. Just my luck.
    1999 Grand Prix GTP
  1. Something does not smell right!
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2013, 01:06 AM
  2. Amp Gets really hot and smell a burning smell?
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2012, 03:13 PM
  3. ? If Hot could have a smell 97 GTP
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-16-2010, 02:11 PM
  4. Bad Smell
    By GMPUNK in forum General Tech Discussion
    Last Post: 07-08-2009, 04:50 PM
