Thread: 91 caprice flooding out after running 5 min
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: 91 caprice flooding out after running 5 min
    I'd stick a fuel pressure gauge on it, maybe see if someone bumped the distributor and put it out of time.
    Maybe see if the EGR is sticking open aswell or the cats clogged.
    My buddy had a 2500 silverado with the 5.0 and the cat plugged up and it would run great and then like crap later, the egr was also an issue aswell.
  2. #22 Re: 91 caprice flooding out after running 5 min
    I doubt the distributors been touched because the car hasn't had anything done to it since this Kid had it. I guess the cat could be clogged but it seems to cut out when it's running bad and comes back if you floor it. I'll probably just delete the egr if it's an issue. Damn obd2 is do much easier lol
  3. #23 Re: 91 caprice flooding out after running 5 min
    Mar 2012
    NC
    I told you Dan, I ran into this same issue with a Cadillac Fleetwood...same engine. Turned out to be a bad O2 and a glitchy TPS.
  4. #24 Re: 91 caprice flooding out after running 5 min
    I might just unhook the o2 and see what it does. Should run fine with it unhooked right?
  5. #25 Re: 91 caprice flooding out after running 5 min
    Cap and rotor and it's running perfect now.
  6. #26 Re: 91 caprice flooding out after running 5 min
    Were the points all nasty and ****?
  7. #27 Re: 91 caprice flooding out after running 5 min
    it aint got no points its an electronic distributor.
  8. #28 Re: 91 caprice flooding out after running 5 min
    On the distributor 3 of the little contacts were melted and the rotor was in bad shape as well. Original at 141k
  1. 1967 Chevrolet Caprice
    By SgtMarshal in forum Off Topic Discussion
    Last Post: 01-21-2014, 08:44 AM
  2. 98 gtp gt flooding
    By IN2DeeP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2012, 10:31 AM
  3. caprice
    By ryanmjw in forum Off Topic Discussion
    Last Post: 08-29-2011, 04:09 PM
  4. Engine Flooding.
    By iroc34 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-05-2011, 01:49 AM
  5. 2011 Caprice
    By pontiac88 in forum Off Topic Discussion
    Last Post: 11-16-2009, 08:21 PM
