Thread: need help.. Haven't been able to drive car in months
Results 1 to 13 of 13
  1. #1 need help.. Haven't been able to drive car in months
    Feb 2014
    United States
    For the past while my car has been starting to act up. After driving for awhile the dash
    will die and the dic will pop up service stability system, service anti lock brakes and so
    forth. the radio will turn off as well. Sometimes after awhile the speedo will turn back on
    but the rest of the dash won't work. Sometimes it'll pop up and say charging system
    failure but that is very rare.
    04 pontiac grand prix gtp
    Thanks for any help yall can give!
  2. #2 Re: need help.. Haven't been able to drive car in months
    Feb 2014
    United States
    BTW somtimes i can turn the car off and can restart it and everything will work fine, other times it wont crank for awhile
  3. #3 Re: need help.. Haven't been able to drive car in months
    What the voltage at while running? Could have a bad alternator
  4. #4 Re: need help.. Haven't been able to drive car in months
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Check alternator or it could be the EBCM needing repair. I know I had to send mine on my 05 GTP out to repair because car was acting up . http://www.grandprixforums.net/threa...S-Off-Solution
    http://www.modulemaster.com/en/index.php Repair place online , they are pretty fast.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  5. #5 Re: need help.. Haven't been able to drive car in months
    Feb 2014
    United States
    So new update. As suggested that it could be the alt and was asked what was the voltage, so I went out to crank it and it wont crank. turn the key and the lights come on but dash is pretty much dead, DIC is dead, radio dead. engine light comes on as it normally would when you first turn key to on position but that's all it'll do. Turn the key to crank and nothing no click nothing. hooked a jump box to battery just to be sure it wasn't that and still same. Headlights and interior lights are bright as can be with or without jump box so battery seems fully charged. Hooked my scanner to it and it won't communicate with the car.
  6. #6 Re: need help.. Haven't been able to drive car in months
    check the 3 grounds on the tranny bell housing, if they are ok, try beating the starter with a hammer, some times they come back to life.
    also check the starter wires are on and tight still.
  7. #7 Re: need help.. Haven't been able to drive car in months
    Mar 2012
    NC
    Sounds like a faulty ignition switch to me...
  8. #8 Re: need help.. Haven't been able to drive car in months
    Quote Originally Posted by Sven Sexman View Post
    it does, i like to cover the dumb things first before dropping that bomb on them, lol
  9. #9 Re: need help.. Haven't been able to drive car in months
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Noone has said the actual issue yet. What it sounds like is actually happening is your CAN bus is dropping out. Adeckers 04 loses the can bus every once in a while from a shoddy remote start install. Gauges all die and no abs or anything else yet the car still stays running. Cannot scan the car once it drops out. I cant say for sure if the can bus is effecting your no start issue but the rest of it sounds like it is your can bus or something on the can bus.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  10. #10 Re: need help.. Haven't been able to drive car in months
    Feb 2014
    United States
    Yeah alot of people said the ignition switch before. Put a brand new GM switch in it still the same issues. On another note, when I was trying to get it to crank and it refused to i may have gotten a little angry and banged the steering wheel and everything popped on and it started. So loose connection somewhere?
  11. #11 Re: need help.. Haven't been able to drive car in months
    ignition switch is not the same as the harness. if banging the column makes it work id change the ignition harness.
  12. #12 Re: need help.. Haven't been able to drive car in months
    Apr 2011
    South Dakota
    An here I am still saying its not ignition power related if he cannot scan it when it happens. Obd2 port has constant power and wouldn't be dropping out with all of the switched power devices. Figure out what is making your can bus unhappy.
  13. #13 Re: need help.. Haven't been able to drive car in months
    May 2012
    Where winter never ends
    what he said
    2000 Regal - Winter Beater
  1. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  2. For those who haven't seen...
    By blueguy in forum Off Topic Discussion
    Last Post: 04-28-2011, 02:44 PM
  3. haven't seen any of these before. are they made?
    By pontiacgp759 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2009, 06:54 PM
  4. Just because I haven't pic whored yet....
    By SD GTP in forum Visual/Body Modifications
    Last Post: 02-06-2008, 11:51 AM
