Thread: Iac keeps throwing check engine light
Results 1 to 7 of 7
  1. #1 Iac keeps throwing check engine light
    Jan 2014
    New Knoxville Oh
    I have replaced it already and everything looks fine idk what is wrong any ideas my motor does pulse any tips
    Taz238
  2. #2 Re: Iac keeps throwing check engine light
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    relearn it
    Turn key for 2 sec then off for 10 sec,on for 2 off for 10 then try starting it.
    If this doesn't work with key on push pedal to the floor hold for 2 sec,then pump it to the floor and release it 5 times in 7 sec
    Also make sure your IAC is adjusted properly
  3. #3 Re: Iac keeps throwing check engine light
    Jan 2014
    New Knoxville Oh
    How do u adjust it properly
    Taz238
  4. #4 Re: Iac keeps throwing check engine light
    Sep 2013
    tulsa okla
    from the bolt hole to the end of the pintle can be no more than 1 and 1/8 inches if it is push it in
  5. #5 Re: Iac keeps throwing check engine light
    Jan 2014
    New Knoxville Oh
    Its in the stock hole that the old one was in I have that slinky looking rubber piece and on the end of that a cone filter
    Taz238
  6. #6 Re: Iac keeps throwing check engine light
    you mean a ait? air intake temp sensor? the little one in the intake tube?
    if so check its wires. look for damage to the insulation like cracks or bare wire showing.
  7. #7 Re: Iac keeps throwing check engine light
    Jan 2014
    New Knoxville Oh
    Ya I didn't see any damage
    Taz238
  1. Check engine light
    By yeghrobe in forum Introductions/Noob Questions
    Last Post: 05-11-2012, 01:59 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Check Engine Light
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-03-2011, 04:10 PM
  5. Check Engine light
    By 04GTPTyler in forum Off Topic Discussion
    Last Post: 03-05-2011, 11:51 PM
