Thread: defroster isnt working and other issues
Results 1 to 10 of 10
  1. #1 defroster isnt working and other issues
    Jan 2014
    Algonquin, IL
    So I noticed a weird smell in my car a couple days ago when running the heat. Along with the weird smell, my defroster wouldn't work, but it still blows air..
    I can hear it still blowing air on the windshield and when i max it out it seems to be blowing both warm and cold but its not defrosting at all
    Also today was the first time i ran it in the daytime and when i run the heat, which works, it also blows out a oderless smoke, almost like a vapor, and the whole car filled with this vapor, which was freaky as f*ck, so i turned it off.
    Any suggestions?
  2. #2 Re: defroster isnt working and other issues
    Jan 2014
    Algonquin, IL
    I have a 05 compg btw
  3. #3 Re: defroster isnt working and other issues
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Heater core? Is the floor wet on the pass side near the firewall?
    Sent from my Galaxy Note 3
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  4. #4 Re: defroster isnt working and other issues
    Jan 2014
    Algonquin, IL
    Quote Originally Posted by mrlogic1234 View Post
    Wow yeah its really wet with like a oil or somthing..wtf
  5. #5 Re: defroster isnt working and other issues
    Jul 2010
    Detroit
    Yep sounds like the heater core or the hoses leading to it has sprung a leak...
    Ryan
  6. #6 Re: defroster isnt working and other issues
    Jan 2014
    Algonquin, IL
    Well is it a easy fix or solution to this or do I need to bring it into a shop
  7. #7 Re: defroster isnt working and other issues
    Jan 2014
    Algonquin, IL
    I'm going to bring it into a gm dealership sometime soon here, thanks for the info mrlogic.
  8. #8 Re: defroster isnt working and other issues
    St. Louis
    If you have time and a heated garage, you can do this yourself and save the $$$ that the dealer will rape you for.
    Check this thread out. Should detail what needs to be done--> http://www.grandprixforums.net/threa...re+replacement
  9. #9 Re: defroster isnt working and other issues
    Nov 2012
    Madison
    When I did mine I looked at the price for shop charge. Hell could be from the 450+.
    Really not hard to do. $100 for core and some anti-freeze.
    Problem is it's cold outside. I did mine in October.
  10. #10 Re: defroster isnt working and other issues
    Jan 2014
    Algonquin, IL
    Yeah its terribly cold, I'll ask around see what quotes I get before I make my decision.
  1. Car cooling fans not working + overheating issues PLZ help.
    By 04GPWhite in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2020, 09:59 PM
  2. window defroster
    By Thinksun in forum General Grand Prix Discussion
    Last Post: 09-18-2013, 05:00 PM
  3. If heater blower isnt working and I tap it it turns on
    By gimphand in forum Audio, Security & Visual Electronics
    Last Post: 06-17-2013, 11:04 PM
  4. Aeroforce was working plugged in obd2..now it isnt?
    By AmericanSoldier in forum General W body
    Last Post: 04-25-2012, 10:06 PM
  5. Chatbox isnt working for me...
    By Tengis in forum Forum Bugs/Suggestions
    Last Post: 12-22-2011, 11:42 PM
